ABS delete questions
Old Jan 20, 2010 | 10:35 AM
WHITEBOY_ZACH's Avatar
Default ABS delete questions
What size are the fittings on the small lines coming out of the booster/master?
What size are the fittings on the 3 hard lines? (2 front, 1 rear)
Is there already a cheap distribution block or should I use 1 double female and 1 T to get it done? I hear people use a block from an IROC (i think)???
Pics when done.
Thanks in advance, all help is appreciated.
ZACH
Old Jan 20, 2010 | 11:16 AM
robsquikz28's Avatar
wrong forum buddy
Old Jan 20, 2010 | 11:27 AM
the_merv's Avatar
Veteran: Air Force
Not necessarily.. I did what he's talking about..I used the Proportioning Block from a '89 Camaro..works like a charm.
I had to custom do one of the Fittings on the Brake Master Cyl..I used a Flare Tool to get the Fittings on the Brake Lines on the K-member to fit right. When I took it off of the '89 Camaro I clipped it off with all the Fittings..I unbolted it from the Master Cyl. so I would have them Lines if I needed them.
Old Jan 20, 2010 | 01:12 PM
Thanks Merv, Ill see what I can find.
ZACH
Old Jan 21, 2010 | 03:33 PM
baylove's Avatar
here you go you can just get a kit that will make it alot easier https://ls1tech.com/forums/lt1-lt4-m...bs-delete.html
this is what im going with when i do my abs delete
http://www.sjmmanufacturing.com/cam_brk_lt1.html
Old Jan 21, 2010 | 03:37 PM
the_merv's Avatar
Veteran: Air Force
I got $5 into mine..and about and hour..can't really beat that..lol.
Old Jan 21, 2010 | 03:40 PM
baylove's Avatar
your so right im just giving him some options so he can see how you and other people have done it to make it easier on him
https://ls1tech.com/forums/lt1-lt4-m...bs-bypass.html
Old Jan 22, 2010 | 04:59 AM
the_merv's Avatar
Veteran: Air Force
Here is my other pic of it..this is the better one..
The Back Brakes are hooked up, I don't have the front ones in yet, but you get the idea..
The Upper Line is the one that I had to drill out the Fitting on..you can see the difference in diameter.
Here is a good pic of it installed..notice the room in there..
Old Jan 22, 2010 | 08:21 PM
n2ocamaro's Avatar
Merv, I am considering going this route. Do you mean the fitting on the Master cylinder of your car or the fitting from the donor car. Why did you have to change it. What was wrong with the fittings on the lines to the k-member?
Old Jan 22, 2010 | 10:56 PM
the_merv's Avatar
Veteran: Air Force
The forward Fitting on the Master I had to drill out to fit the bigger line you see there..I don't know if that was necessary, but the Gen III was like that so I matched it.
Nothing it wrong with the Fittings on the K-member, you have to re-flare one of them with the Fitting off of the Gen III.
Old Jan 23, 2010 | 03:13 PM
n2ocamaro's Avatar
I see what you mean now. Thanks for the info.
