cruise control delete
Old Jan 23, 2010 | 11:55 AM
Barney Z's Avatar
Originally Posted by Badazz 97 TA
how many times do you actually set off your ABS when driving? hardly ever? The brake will still work normal, just no ABS
The cruise control will still work. All you need is a cruise control cable from a non TCS car. Since the cruise and throttle cables connect to that servo above the valve cover.
Youre right and I see your point. Only thing is I dd this car at the moment and probably will be for the next year or so. Kinda hesitant to do anything to mess with the brakes period. But may anyway.
Old Jan 23, 2010 | 11:59 AM
the_merv's Avatar
Veteran: Air Force
With mine the ABS is gone, but it's not my DD.
Originally Posted by Barney Z
Which would be?
On the Throttle Body next to the Throttle Cable in the Bracket..it clips on to the outside on the little tab that sticks out. You'll know it when you see it.
Old Jan 23, 2010 | 12:04 PM
Badazz 97 TA's Avatar
Mine has a been a DD for the last 2.5 years. Through snow and rain(Wisconsin). I got through it just fine. Just be smart about. I personally hate ABS so it wasnt a big deal to me. Some people like it, thats fine. Whatever makes you feel more comfortable. Im not gonna fight you about it, i was just saying....
Old Jan 23, 2010 | 12:51 PM
Barney Z's Avatar
oh, I gotcha. Thought you meant moving the actual box.
Old Jan 23, 2010 | 12:54 PM
Barney Z's Avatar
No, man, I appreciate any info and feedback, and youre right. Probably what Ill do. Hell, Ive never had it actuate yet, anyway. Got to thinking about my 99 Z71. The abs on that damn thing almost CAUSED a couple wrecks for me. Im assuming just pull a fuse to make the dash light go out?
Old Jan 23, 2010 | 12:57 PM
the_merv's Avatar
Veteran: Air Force
Na. Just where the Cruise Cable goes after you change it.
Anyone have a source on one of them Cables..I need one for mine too..it got messed up and I'll have to replace it.
I was thinkin Junkyard, but if someone has one that will help..
Old Jan 24, 2010 | 12:47 PM
96blackta's Avatar
I've been driving around the longest time with my ABS INOP light on, which is in fact WORSE than not having ABS at all. My rear brake lines are locked up hence no rear brakes.
Old Dec 22, 2011 | 12:13 PM
urbex's Avatar
Yeah, new guy, first post, pulling old thread out of the grave...I know, mass horrors!
Anyways, I have a '96 Z28, with a 9" swapped into the rear, without any of the ABS stuff installed in the axle. Obviously that makes the ABS non functional, which isn't the end of the world for me, but I really do miss having functional cruise control (especially with having a 2+hour commute to work every day)
I was under the impression that due to the linking of the ABS system and the Cruise system, that if the ABS isn't working, neither is the cruise. But reading over this thread, it sounds like some guys have done the ABS/TCS delete, but still have working cruise? As far as I know, my car never had TCS to begin with, and I don't have the box on the driver's side valve cover.
I don't have the money to have major axle work done right now (and with the Detroit locker in there, I'm not sure it's even possible to have ABS stuff installed), but is there some way to get the cruise working without the ABS?
Old Dec 28, 2011 | 10:03 PM
urbex's Avatar
Did some basic troubleshooting over the weekend, found the switch signals from the multi-function lever weren't getting to the control module. I picked up three more levers from the junkyard today, none of which fixed the issue. So I'll need to check continuity on the wiring down the steering column to see if the problem is there. It's been colder than a witch's tittie here the last few days, so I'll try again when it warms up a bit and report back. THanks guys
