cruise control delete
Old Jan 22, 2010 | 05:15 PM
twokss's Avatar
Default cruise control delete
hey guys. i just picked up a 96 t/a for a daily driver. where can i locate a non cruise control cable so i can get rid of this monstrosity on top of my valve cover?
Old Jan 22, 2010 | 05:25 PM
96blackta's Avatar
http://www.hawksthirdgenparts.com/br...S--NEW-GM.HTML
I bought mine used on the forum though.
Old Jan 22, 2010 | 05:31 PM
twokss's Avatar
hmmm...that one says "with out cruise control". which i have...think that matters?
Old Jan 22, 2010 | 05:37 PM
Spartan7's Avatar
Originally Posted by twokss
hey guys. i just picked up a 96 t/a for a daily driver. where can i locate a non traction control cable so i can get rid of this monstrosity on top of my valve cover?
Fixed. The dealer should still carry the throttle cable, but if you want to keep cruise, you need the cable for that as well. That however is discontinued, but I was able to get one from the dealer because they had an extra in the warehouse.
Old Jan 22, 2010 | 05:47 PM
twokss's Avatar
wait...forgive me i have a good buzz on right now. so that ugly transformers looking mechanism over my drivers side valve cover is the traction control and not cruise? i read on another forum that it was the cruise. i really don't care about cruise, i just don't want all this clutter under my hood. so please point me in the right direction.
Old Jan 22, 2010 | 05:52 PM
kierstyn's Avatar
Cruise control is located in the driver side front fender or bumper on the frame rail. Trace the cable to it!
Old Jan 22, 2010 | 06:07 PM
96blackta's Avatar
Oh, I should have explained. The box on your valve cover is the TCS. To delete that you need the cable in the link I provided. You won't have TCS or cruise control after.
twokss's Avatar
ok so the cable in the link above is the cable i want to delete the traction control located above my valve cover? I might as well get rid of the cruise control as well being as i never use it. will i need a separate cable for that as well? sorry for the stupid questions. im new to the lt1 scene. (i tried a search, i know that remark is soon to be followed)
Old Jan 22, 2010 | 06:08 PM
twokss's Avatar
oh ok. you beat me to it. so the cable linked above will delete my cruise and tcs? nothing else will be needed?
Old Jan 22, 2010 | 06:09 PM
RamAir95TA's Avatar
You won't need a new cable for the throttle cable. Just remove the box and cable - it's a seperate cable.
Old Jan 22, 2010 | 06:17 PM
twokss's Avatar
hi joe. lol ac? shoot me a text or call or something when you get time
Old Jan 22, 2010 | 06:20 PM
RamAir95TA's Avatar
Gimme a break...I'm still sick...brain farts aplenty.
Old Jan 22, 2010 | 06:23 PM
96blackta's Avatar
All you need is that one cable. You will install it so that it connects directly from your gas pedal to the throttle body. Everything else that was connected to the box is now dead weight and should also be removed.
Old Jan 23, 2010 | 06:42 AM
Barney Z's Avatar
Sorry, my heads still spinning rom last night, but yall are saying you cannot delete tcs without deleting cruise? That sucks. . . I wanted to get rid of that ugly *** thing too but hoped I could keep my cruise. . . . . .
Old Jan 23, 2010 | 07:21 AM
FASHOOTER's Avatar
I believe you will not have ABS, once you remove TCS
Old Jan 23, 2010 | 07:33 AM
the_merv's Avatar
Veteran: Air Force
Delete everything..**** it all..lol
Then re-install the Cruise to the proper location.
Old Jan 23, 2010 | 08:29 AM
Barney Z's Avatar
Which would be?
Old Jan 23, 2010 | 11:13 AM
Barney Z's Avatar
and if thats the case im not gonna do it. Anybody have a fix for that?
Old Jan 23, 2010 | 11:34 AM
Badazz 97 TA's Avatar
how many times do you actually set off your ABS when driving? hardly ever? The brake will still work normal, just no ABS
The cruise control will still work. All you need is a cruise control cable from a non TCS car. Since the cruise and throttle cables connect to that servo above the valve cover.
Old Jan 23, 2010 | 11:48 AM
RamAir95TA's Avatar
...except the one time you need it and it isn't there. That's kind of an ignorant statement. Safety is worth it to some people.
I should point out that my ABS is long gone, but it isn't my DD.
