Installing LPP headers rean into a problem.
Old Jan 25, 2010 | 05:37 PM
xxRONNIExx's Avatar
Default Installing LPP headers rean into a problem.
Okay I received my LPP's this mourning and decided to start installing them by myself. I removed the alternator, and A.I.R. All drivers side exhaust manifold bolts are removed.
Okay hopefully I can explain this right. The cat thats connected to the exhaust manifold has 3 nuts. I got all the nuts off and both driver and passenger side but ONE!! I think I stripped it..I cant get a good grip on it. What the best way to take this nut off now that it may have been rounded? Thx
I have a few pic as well.
http://img64.imageshack.us/i/80786453.jpg/
http://img163.imageshack.us/i/24924649.jpg/
http://img33.imageshack.us/i/80703842.jpg/
Old Jan 25, 2010 | 06:11 PM
SoxXpupPeT's Avatar
just cut the pipe and remove the manifold and pull it from the top. or bottom. howewver you can get it out. dont forget to remove the steering knuckle
Old Jan 25, 2010 | 06:14 PM
LT1John's Avatar
cut the pipe for sure. I got Leginfelter Long tubes. Didnt have to touch the steering nuckle
Old Jan 25, 2010 | 06:42 PM
I8ASaleen's Avatar
Spray some PB blaster on it, let it sit for awhile, then hit it with an impact with an extension. That's how I got all of mine out.
Old Jan 25, 2010 | 06:47 PM
xxRONNIExx's Avatar
All sound like good ideas thanks guys.
Old Jan 25, 2010 | 06:49 PM
xxRONNIExx's Avatar
Im hoping with these headers I wont have to touch the steering knuckle
Old Jan 25, 2010 | 07:07 PM
SoxXpupPeT's Avatar
im not saying they will. but with the steering shaft out of the way it gives you alot more room to work with in that tight bay
Old Jan 25, 2010 | 07:33 PM
xxRONNIExx's Avatar
Ahhh okay got it
Old Jan 26, 2010 | 11:02 AM
Adam96z's Avatar
Steering knuckle only takes 5 mins to remove or install.
Old Jan 26, 2010 | 11:06 AM
ADM's Avatar
ADM
Mine also rounded out. I just cut the pipes and removed them as a piece.
Old Jan 26, 2010 | 03:28 PM
94Z28rag's Avatar
I'm just going to cut mine off if it gives me any lip. You don't need to save it or use it anyways.
Old Jan 26, 2010 | 07:36 PM
xxRONNIExx's Avatar
Yep I just cut mines off but way to go!!
