Replacement clutch on the cheap
Old Jan 30, 2010 | 01:27 AM
gregrob's Avatar
Originally Posted by speed_demon24
I had one and wouldn't reccomend it. If the clutch had any amount of heat in it it would slip. Kevlar clutches + heat = fail
The Mcleod street strip disk I was looking at said it was organic, not Kevlar...
Old Jan 30, 2010 | 11:10 AM
speed_demon24's Avatar
Organic on both sides defiantly won't hold your power.
Old Jan 30, 2010 | 11:40 AM
69gto96z's Avatar
Pretty sure that's the route I'm gonna go. Did you reuse your original pres plate or buy a new one? How much power is it holding?
Thanks
Its a new PP. The car made 346/347 on the dyno, and saw a 100 shot a couple of times a couple years ago. On that note, when I was full bolt ons and spraying a 150 shot, about a bottle a week, I had a cheap autozone clutch package in there, it held up great.
Old Jan 30, 2010 | 12:24 PM
BALLSS's Avatar
[QUOTE=speed_demon24;12816886]I had one and wouldn't reccomend it. If the clutch had any amount of heat in it it would slip. Kevlar clutches + heat = fail
...I found "kevlar" disc material to hold very well....with heat
From the looks of your pics of the McLeod disc it was organic material on one side (aka stock) and a composite puc type on the other (may have some kevlar in it??)
my ZOOM HP is Kevlar/Kevlar puc type on both sides.....and holds well running a tire in a 4200 lb car with 383...FWIW
Attached Thumbnails Replacement clutch on the cheap-lt-1-clutches-051.jpg   Replacement clutch on the cheap-lt-1-clutches-053.jpg
