Need a coil...which one?
Old Jan 27, 2010 | 09:33 AM
ssbowtie1's Avatar
Default Need a coil...which one?
Putting my 96 motor in a 95 car so I'm going to be needing a 95 coil. From what I understand I can use the same ICM but I need a different coil.
I was thinking of buying an aftermarket coil but it seems like every coil has a substantial failure rate.
Is the best option to buy a GM coil? A new GM coil will run me quite a bit more than an aftermarket coil and will take longer for me to receive it.
I can also buy a used one, but likely with high mileage. Do GM coils usually fail at high mileage?
What have your experiences been?
Old Jan 27, 2010 | 09:37 AM
RED94Z28's Avatar
I have had good luck with my msd blaster coil..
Old Jan 27, 2010 | 09:50 AM
djjab57's Avatar
Msd blaster was ok except the clip broke on mine, the Hypertech works goods ad well. Only problem i had was i had the stock wires on at first and spark was shooting out the coil wire
Old Jan 27, 2010 | 12:07 PM
the_merv's Avatar
MSD Blaster.
Old Jan 27, 2010 | 02:50 PM
ssbowtie1's Avatar
MSD Blaster seems to be popular.
Has anyone had a failure with a MSD Blaster? I have no problem paying the extra scratch and waiting longer for a new AC Delco piece if its failure rate is that much lower. My car is only a bolt on daily driver.
Old Jan 27, 2010 | 02:54 PM
Toronto LT1's Avatar
been running MSD blaster for over two years without issues.
Old Jan 27, 2010 | 03:11 PM
djjab57's Avatar
Like ive said ive ran most all of them, for a bolt on DD the $15 from auto zone works great
Old Jan 27, 2010 | 10:34 PM
ssbowtie1's Avatar
One more chance for any horror stories with the MSD Blaster before I order it tomorrow
Old Jan 28, 2010 | 10:39 PM
MattSapp95_T/A's Avatar
MSD Blaster here too going strong!
Old Jan 28, 2010 | 10:44 PM
AChotrod's Avatar
stock ftw!!!!
Old Jan 28, 2010 | 10:45 PM
SS MPSTR's Avatar
Stock.
Old Jan 28, 2010 | 11:34 PM
bigj2717's Avatar
+1 for the MSD I've have mine for 5 years and never had a problem
Old Jan 28, 2010 | 11:41 PM
bore.me's Avatar
I've heard the higher-output coils like the MSD can will wear out the cap and rotor on the optispark faster than a stock coil. Is this true?
Old Jan 28, 2010 | 11:49 PM
bigj2717's Avatar
I put mine on an opti with 100+k on it and it lasted till about 200k till I blew the motor and decided to replace it
Old Jan 29, 2010 | 12:02 AM
94maro's Avatar
i would not recrment the summit brand or the msd blaster one ive had two blasters go out on me and the summit one broke in the frist week..so i went with the ac delco one works good for me..
Old Jan 29, 2010 | 12:40 AM
Wicked94Z's Avatar
blaster here... don't get the crappy autozone coil, it will missfire above 5800. That was when i had boltons as well, not a built motor.
Old Jan 29, 2010 | 02:19 AM
ssbowtie1's Avatar
Well sorry guys too late I already ordered the MSD blaster so if it goes bad on me you're all to blame.
