View Poll Results: Which one
Aluminium
13
68.42%
Steel
4
21.05%
Doesn't matter
2
10.53%
Voters: 19. You may not vote on this poll
upgrade drive shaft?
Old Jan 29, 2010 | 08:44 PM
pillarpod's Avatar
Default upgrade drive shaft?
I can't make up my mind if I want to get an aluminum drive shaft. Pro. its less rotating mass. Con. Steel one is much stronger.
Old Jan 29, 2010 | 08:55 PM
JeaneZ28's Avatar
They're aluminum driveshafts that will hold 1000+ HP and chrome moly is another choice. How much HP do you have?
Old Jan 29, 2010 | 09:26 PM
airfix's Avatar
Go Chrome moly or aluminum.
Old Jan 29, 2010 | 09:29 PM
Elliott's94Z's Avatar
If you have other bolt on stuff engine wise to do, then I would go that route first. I'm running a aluminum with my AI set up with luck. Have my factory Steel on standby in case it goes pop. The aluminum is good for a few extra ponies but not worth the money if you need to spend it in other areas.
Old Jan 29, 2010 | 09:39 PM
pillarpod's Avatar
Next is After market heads, custom cam and a Yank3600....still go with the aluminum?
Old Jan 29, 2010 | 09:40 PM
pillarpod's Avatar
thats is unknown at the time, till i get it dyno after the H/C swap
Old Jan 29, 2010 | 09:42 PM
If you have the extra cash laying around then go for it. I would keep your steel one on hand if something does go wrong. Also another thing you might want to invest in is a Driveshaft Safety Loop. The Aluminum's are known to break and you will wish you had a DS safety Loop on if it does. They are cheap insurance.
Old Jan 29, 2010 | 10:58 PM
MasterTomos's Avatar
+1 on the safety loop, all major aftermarket suspension/chasis companies make them.
If yur really worried...just go carbon fiber!
Old Jan 30, 2010 | 07:51 AM
JeaneZ28's Avatar
For the power you're going to have there are aluminum and chrome moly driveshafts that can easily handle that power.
Old Jan 30, 2010 | 11:49 AM
pillarpod's Avatar
Whats special about the carbon fiber ones? I don't know a darn thing about Carbon Fiber
Old Jan 30, 2010 | 12:43 PM
Here is a link to the Inland Empire DS. Myself and others local run them with great results.
http://www.iedls.com/
Old Jan 30, 2010 | 12:59 PM
qc97z's Avatar
I bought a TPiS aluminum d/s. I think I paid like $260 for it on Ebay. It was NIB. It is stronger than stock...so I'm not sure what others are talking about when it comes to strength. If you compared steel to aluminum at the same wall thickness, they're right...but the aluminum shafts you buy have much thicker walls. If it weren't for me getting an aftermarket rear end soon and having to have a different d/s, I'd be using my same d/s for my build, which will be putting out about 600 rwhp.
I'm pretty sure you'd be just fine with an aluminum D/S with your current plans. Probably an LS1 D/S will be just fine, you could pick one up pretty cheap.
Old Jan 30, 2010 | 01:34 PM
JeaneZ28's Avatar
It is the lightest thing that can withstand tons of HP.
Old Jan 30, 2010 | 01:50 PM
baylove's Avatar
and its about $800 for that carbon fiber drive shaft
Old Jan 30, 2010 | 02:11 PM
what a waste of $$$$
Old Jan 30, 2010 | 02:19 PM
RamAir95TA's Avatar
Denny's nitrous-ready chrome-moly driveshaft with 1350 yokes. No compromises. While an aluminum shaft is definitely lighter, you can offset the weight of a chrome-moly shaft by lightening up other parts of the drivetrain that aren't weakened by switching to a different alloy (such as using an aluminum wheels).
I don't like using carbon fiber driveshafts for drag-racing purposes, because they are more pliable than aluminum or steel and can detract from the initial "hit" of a hard launch.
Old Jan 30, 2010 | 02:30 PM
StealthFormula's Avatar
Why don't you just pick up a used LS1 aluminum DS for ~$100? With your current mods and future mods you won't need anything better than that. I forget the weight difference between the stock steel and the aluminum LS1 but IIRC it was about 5-7 lbs. or so when I weighed them. Throw a DS loop in the mix and your set. I've been cutting 1.5 60's with mine and it hasn't skipped a beat.
Old Jan 31, 2010 | 02:22 PM
pillarpod's Avatar
Thanks for all your input guys...looks like i will be buying an aluminum DS
Old Jan 31, 2010 | 07:00 PM
pillarpod's Avatar
i found these weights on lt1engine.com and just wanted to share it for people in the future.
16 lbs - Stock steel LT1 driveshaft
12.2 lbs - 3rd gen aluminum 1LE driveshaft
12 lbs - LPE aluminum driveshaft
11.5 lbs - Stock aluminum LS1 driveshaft
10 lbs - RK Sport aluminum 1pc driveshaft
