5.7" or 6" rods??
LT1 SB 350 bored .060 (362)
Mahle PowerPak Pistons
Stock Crankshaft turned to .010 rod/.040 main journals
AFR Heads modded by TPiS, Manley 2.02/1.65, 187cc, 54cc chamber
.600 lift Springs
Comp Cams 1.6 Self-Aligning RR's
Trick Flow 7.200" Chromemoly Pushrods
LS7 Lifters
TPiS ZZ409 Hyd Roller Cam, Adv. Dur. 287/287, Dur. @.050 226/226, Gross Lift .520/.520, Lobe Sep. 112
Stock Repl. Opti w/ MSD Cap and Rotor Kit
MSD 8.5mm Wires routed OTVC
MSD Heavy Duty Coil
MSD 6AL Ignition Control
30# SVO Fuel Injectors
Walbro 255 Fuel Pump
Ported Stock Intake Manifold
58mm Throttle Body
Moroso Cold Air Intake
LPP Long Tube Headers and Y-Pipe
3" Exhaust w/SLP Loudmouth I Resonator, No Cats
Resurfaced Stock Flywheel
Stage 3 Clutch
LS1 Aluminum Driveshaft
4.10 Gears
MAC Rear End Girdle
Custom Dyno Tune
Other Upgrades:
BMR STB
BMR SFC's
Eidbach LCA's
BMR LCA Relocation Brackets
BMR Panhard Rod
BMR Driveshaft Loop
Long list but I just wanted to cover everything. The only other things I plan on doing to the car is upgrade to some 205cc heads and maybe play with the cam. Thats it.
I'm kinda making a point here with the last few posts. LS1tech [LT1 secton] looks busy, but whenever I come hear it's "Best CAI" or "Will a LS1 catback fit my LT1". Just try searching guys, lots of people have already walked this path and asked those questions.
CamaroZ28.com has a ton of good info. Used to be THE LT1 spot.
-Dustin-
And yes your right, but EVERY engine combo is different. Some people will get a different answer than me and I am not going to take a chance of messing up my car because I overlooked something somewhere.
And the rod length isnt going to hurt you motor.
-Dustin-
Now having said that........because you're running that ZZ409 cam with less than optimum valve events, especially overlap, I see a tiny advantage to the added TDC dwell you'd get with the 6" rods.
btw, I'm curious why you're thinking of changing from the AFR heads. Did TPIS do any porting on them? If not, you have a good set of castings already in your hands to make great power in the hands of a good porter.
Why do you guys never talk about ring package? Lot's of N/A HP available.
