le2 vs trickflow
Old Jan 31, 2010 | 07:18 PM
6801's Avatar
Default le2 vs trickflow
hi im new here and to lt1s i have a 95 z28 m6 i have all the normal bolt ons including longtube headers and 3.73 gears im currently am dropping my cradle to freshing things up and have a goal of 400 rwhp and break into the 11s heres my question im understanding mr elliot is a porting wizzard and his combos are proven but what route should i go because hes in texas and im 30 min from summit racing in ohio
le2 heads and cam with ported intake 1875+
or trick flow 180 heads and comp 306 cam to remain 54cc for compression
im on a budget of about 3500$ including injectord bigger tb rockers gaskets ext
le2 flow better but i have to pay shipping and down time but hes proven to get the right numbers
trickflow route and cam 1700 plus a local guy will sell me his ported intake 58mm tb and nitrous kit for 600 with msd ignition help how much power would the trickflow make
Old Jan 31, 2010 | 07:23 PM
RamAir95TA's Avatar
You should also consider www.advancedinduction.com. Your best bet is to contact both vendors and talk to them about your goals and they'll be able to help you out, no questions asked. You have a healthy budget for valvetrain so you're definitely on the right track.
Old Jan 31, 2010 | 07:31 PM
marc97taws6's Avatar
AI or LE will take care of you.
Trickflow 180cc heads? I would step up to their 195cc heads at least if you are going to go that route.
I would just recommend having them ported by either LE or AI, buy that nitrous, ported intake, 58mm TB, ignition, and be set
Old Jan 31, 2010 | 07:33 PM
6801's Avatar
ther to expensive for me even thoug ther also top of the line budget has to include tune clutch or whatever i need hopefully i have enough to get tires haha
Old Jan 31, 2010 | 07:38 PM
RamAir95TA's Avatar
The AI 190cc's are comparable to the LE2 heads and are $200 cheaper, so not sure on where you're getting that info (the 200cc's are more comparableto the LE3s). I'm not trying to sell you either way - just making you aware of the options that are available.
6801's Avatar
i dont want to loose compresion what do you think the power diffrence would be between le and trickflow i think le2 flow 270 and trick flow 255 are combadable to le 1 heads
Old Jan 31, 2010 | 07:46 PM
BlueRamAir's Avatar
With LE1 heads and a cc306 cam and a good tune 11's are still possible. than use the nos to go deep in to the 11's.
Old Jan 31, 2010 | 07:49 PM
TravisMcGill2000's Avatar
look into the new 21* trickflow heads. They are 185cc intake runners,54cc, and flow 273. They are 1600 after taxes.
Old Jan 31, 2010 | 07:51 PM
kierstyn's Avatar
the new trickflows are supposed to be around 280 i think dont buy the old ones or you will losen some compression. I think either would be good with the trickflows you could always have them ported bigger for a stroker motor later down the road.
Old Jan 31, 2010 | 07:52 PM
kierstyn's Avatar
lol beat me to it asshat!
Old Jan 31, 2010 | 07:54 PM
AChotrod's Avatar
LE2s with the right cam can put you in the low 11s..... if the rest of the car is up to it. prob even better with an Auto
Old Jan 31, 2010 | 08:03 PM
6801's Avatar
i was unaware the ai were cheaper they would be the new trickflow 185 im sorry if i wrote it wrong i could have them ported eventuly im going stroker but for this year i need to see the 11s the suspension and rear end is set up i have 3 10 bolts
Old Jan 31, 2010 | 08:41 PM
$1395 + core + cam for 190cc AI heads as listed on their site
$1995 + core is the price for their 200cc heads and cam
LE2 heads and cam is $1600.
I think either choice would give you impressive gains
Old Jan 31, 2010 | 08:51 PM
bowtienut's Avatar
6801, You'll be selling yourself short and wasting time and money if you go with the out-of-the box Trickflows (although I can't speak for the 21 deg heads).
Both the AI 190 and the LE2 heads are a smart step to reach 400 rwhp; the as-cast TF 180's or 185's are not. I'd be inclined to run the stock heads with a good cam (you can do much better than the CC306) rather then just bolting on those TF's. And I'm not badmouthing TF in particular; the same goes for AFR's and others. Cam-only won't get you to 400 rwhp, but will easily run 11's if the rest of the car is up to it and you can launch that M6.
It's too bad you're not closer to Dayton. One of the best LT1 builders in the country is there, Mike Harris. He used to do his own heads and they were kick@ss, but found he couldn't compete with AI on value, so he now uses their heads for all his builds.
Old Jan 31, 2010 | 09:03 PM
jaycenk's Avatar
Trickflow made like 360hp with these heads. LE2 should be closer to 400, and advanced will get you 400+ at the wheels with N/A.
Old Jan 31, 2010 | 09:21 PM
6801's Avatar
thanks ai heads and cam for that price who can beat that for that price ill givem a call thanks i didt think out of the box head would get me therei have the itch and deciding within the next few days im def gona buy the nitrous kit
Old Jan 31, 2010 | 10:08 PM
AChotrod's Avatar
LE will get you 400+ also
Old Feb 1, 2010 | 12:45 PM
robsquikz28's Avatar
A.I heads for $1395+ cam it will still be $1695 and the L.E2s with cam is the same price.
So going with either company will be good, you just have to make ur choice of what you want.
Old Feb 1, 2010 | 04:39 PM
slomarao's Avatar
how big of a cam are you planning on running?
If your going with a cc306/GM 847 your not going to need the best heads and will still be able to make 400rw.
Now if you dont want anything bigger than a hotcam or crane 227, etc your going to need better heads to make up for the small cam.
As Blueramair stated, you can get into the 11's with le1's and a cc306 or similar cam. i agree.
Old Feb 1, 2010 | 05:16 PM
SixShooterCam's Avatar
im shooting for high 10's low 11's with LE2 heads and stock crank with a .030 bore on the LT1 with forged pistons and rods and 150 shot
