crank Hub removal
Old Feb 2, 2010 | 04:30 PM
boostedpower's Avatar
Default crank Hub removal
So i have unbolted the timing chain cover and the oil pan, and removed the pulley, now for the hub, the only problem is, it spins whenever i try and loosen it, any ideas?
Old Feb 2, 2010 | 04:56 PM
RamAir95TA's Avatar
You need a crank hub puller.
Old Feb 2, 2010 | 05:01 PM
SixShooterCam's Avatar
http://www.lt1engine.com/tech/remove...lt1-crank-hub/
Old Feb 2, 2010 | 07:46 PM
MTBSully's Avatar
^^^ what they said.
that is one dirty LT1
Old Feb 2, 2010 | 09:21 PM
litch2004's Avatar
i think he is referring to the bolt holding the crank hub to the crank snout. If i am right it looks like you have the engine pulled. You will have to find someway of keeping the flywheel/flexplate from rotating while you remove the crank hub. Then like others stated you will need a crank hub remover to remove the hub. GL OP
Old Feb 2, 2010 | 09:40 PM
BlueRamAir's Avatar
http://www.youtube.com/watch?v=qkh1BNM7e6Q
Old Feb 5, 2010 | 04:00 PM
yes, I did pull the motor, and I am thinking about putting a piece of wood under the crank hub to keep everything from spinning... anyone try this with any results? I need to get this camshaft in today! thanks guys
Old Feb 5, 2010 | 05:00 PM
aboatguy's Avatar
You can use a BF Crescent wrench to hold one of the three ears on the hub....
Old Feb 5, 2010 | 08:00 PM
SS RRR's Avatar
Village Troll
If it's an auto then you can try the methods listed. If it's a manual and your e-brake works, put the transmission in 5th gear and pull the e-brake.
Old Feb 5, 2010 | 08:30 PM
bigj2717's Avatar
The wood is not going to work. Try an impact or get a big *** wrench to hold the hub
Old Feb 5, 2010 | 11:11 PM
I think I'm going to try my impact tomorrow, the wrench didn't work, I used a breaker bar and the whole motor and tranny lifted up and it just rotated over the wrench, so i guess impact is the way to go, I'll let you guys know tomorrow, Also just ordered headers and gm syncromesh for the tranny! I hope for some big gains with this setup! thanks for all the help you guys... any new idea are welcome!!!
Old Feb 6, 2010 | 02:01 PM
aboatguy's Avatar
How did the wrench not work...Just use a bf knuckle buster and use one hand on each wrench it should be easy the bolt should not be torqued high enough to be an issue.....
Mike
Old Feb 6, 2010 | 02:09 PM
NemeSS's Avatar
thats one crusty lt.
dam, looks like is the first time the crank hub has come off.
