porting intake mani
Old Feb 3, 2010 | 05:58 PM
nik1703's Avatar
Default porting intake mani
when i do my cc503 upgrade, i'm looking at about 40rwhp gain, right?
would it be worth my time/money to have the intake manifold ported at the same time? are we talking a noticeable difference in power from porting the manifold?
Old Feb 3, 2010 | 06:08 PM
draggin97s10's Avatar
gasket match it yourself not to hard.
Old Feb 3, 2010 | 06:10 PM
97Z28SS's Avatar
Unless your heads are ported or gasket matched I wouldn't bother because the lack of head flow is a bigger barrier to gaining hp/tq then the intake is at this point. Now that said if you just want to have it done while the intake is off, I don't think it will hurt you any.
Old Feb 3, 2010 | 06:15 PM
robsquikz28's Avatar
You would not gain anything with stock heads. That cam putting out 40hp maybe, maybe not! All cars are different and depends on what other supporting mods you have already? A4 or m6? Ive seen that cam only put out 25hp over stock but it depends on what you have.
Old Feb 3, 2010 | 06:29 PM
nik1703's Avatar
Everything is in my sig. manual transmission. headers, y pipe, slp catback, intake, throttle body, tune.
obviously i'd need to retune the car after all that.
so it seems the concencous is not to port the intake?
Old Feb 3, 2010 | 07:16 PM
Z28Camaro30Ann's Avatar
Like they said. Without porting your heads, porting your intake manifold will do nothing. It wont HURT...but the flow can only go as fast as the smallest part and that would be your heads. The air will still flow the exact same way basically.
If you port your heads though then it will definately benefit you to port the intake manifold.
It is up to you what you want to do. If you wanna port it now, go for it lol, wont cause any problems...If your having someone else port it though why not save the cash and put it into something else? Just my opinion
BOLO's Avatar
I agree. 40 rwhp? maybe 40 at the crank.
Old Feb 3, 2010 | 08:05 PM
Elliott's94Z's Avatar
There are guys on here that have lost out on power by intake manifold porting. Ron at AI and I talked about this during my time of purchase. If I remember correctly, Speed Demon gained a substantial amount of HP by switching back to a stock OEM manifold from a ported. If you do get it ported I would send it to Advanced Induction and have them do the work.
Old Feb 3, 2010 | 09:46 PM
speed_demon24's Avatar
I lost 5-10rwhp by going with a ported intake by a vendor on here. I made 430rwhp with a stock intake on my current setup so I don't think it's holding me back that much if any. A ported intake will do more harm than good on a stock headed car.
Old Feb 3, 2010 | 09:51 PM
SoxXpupPeT's Avatar
gasket match. i did it. but i also gasket matched my heads to not creat turbulence from the ridge difference
Old Feb 3, 2010 | 10:44 PM
za355tx's Avatar
Plain and simple don't even bother. Lloyd says you need to be spinning some pretty high RPM's to pick up anything. Without ported heads it's pretty much pointless to even touch it. Even gasket matching isn't going to do anything for you. Even with a set of ported heads...with a cam that size you would probably not see any hp gains with a ported manifold. That cam is not made to spin much more than 6k. Many guys shift that cam at 6100-6200 and at that RPM a ported manifold would barely be getting started making more HP over a non-ported piece.
It's really not worth the time and trouble to touch a stock manifold, unless you're build is pretty wild. But I also need to agree with some of the other guys. That cam is not going to net you 40rwhp more. More reasonable is 25...maybe 30 with a good tune. A cam that size is not going to bump you 50 hp at the crank.
Old Feb 4, 2010 | 01:12 PM
You have me wondering if I am hurting because of my ported intake...being we went with the same vendor. I have a stock unported laying around I want to swap on and have dyno'd with to see if my numbers change for the better.
Old Feb 4, 2010 | 01:25 PM
slomarao's Avatar
as mentioned, do your heads than the intake.
Old Feb 4, 2010 | 01:37 PM
BLWNLT1_T/A's Avatar
What if you have off the self 62cc heads and gasket match both? This will be on a turbo car.
