Had a quick question..
Old Feb 6, 2010 | 12:55 AM
rg501's Avatar
Default Had a quick question..
i noticed that theres a crack in this hose thats connecting to my throttle body. you can see it here in the pic..
is this a big deal? what hose is that?
Old Feb 6, 2010 | 01:08 AM
jaycenk's Avatar
That is from the PCV on the valve cover. It's an engines bad habit lol. just replace it. If it is cracked it is a vac leak so don't let it go for long.
Old Feb 6, 2010 | 01:08 PM
RamAir95TA's Avatar
Yep - it's the fresh air supply hose for the PCV system. It will result in a vacuum leak.
Old Feb 6, 2010 | 01:26 PM
rg501's Avatar
and what happens when there is a vacuum leak?
Old Feb 6, 2010 | 01:45 PM
RamAir95TA's Avatar
A vacuum leak (if large enough) can cause a high idle, rough idle, hard starting, hesitation, misfiring, and a lean condition, by letting in unmetered air into the combustion process.
