msd digital 6 ignition box
Old Feb 8, 2010 | 06:59 AM
kalebm22's Avatar
Restricted User
Default msd digital 6 ignition box
is this a good box to use on an lt1? i need something that will pull a couple degrees of timing out of my tune when i turn the nitrous on. so is this the best option? or what are you guys runniing?
Old Feb 8, 2010 | 07:51 AM
bigj2717's Avatar
The 6a does not pull timing it's a multiple spark box
Old Feb 8, 2010 | 09:09 AM
1redta's Avatar
the digital 6 will pull timing out with activation of a nitrous solenoid. I have had a couple of freinds use it with good success
Old Feb 8, 2010 | 09:59 AM
black95z28's Avatar
I use the digital 6 to pull timing when the nitrous solenoids are active as stated above. Works great. I have mine mounted under the passenger seat.
Old Feb 8, 2010 | 10:34 AM
bigj2717's Avatar
Sorry I was thinking of a different box
Old Feb 8, 2010 | 11:31 AM
MattSapp95_T/A's Avatar
Yep a digital 6 is what I use too....
Old Feb 8, 2010 | 11:36 AM
kalebm22's Avatar
Restricted User
im glad to hear there is several people using it. how much can u safely spray on a naturaly aspirated tune when this thing is activated? or is there any tips you guys have?
Old Feb 8, 2010 | 03:12 PM
86formula's Avatar
as long as its a wet shot i believe a nitrous tune is basically a N/A tune with some degrees of timing pulled
Old Feb 8, 2010 | 03:47 PM
AChotrod's Avatar
Ive got a Dig 6 also!!
Old Feb 8, 2010 | 10:03 PM
kalebm22's Avatar
Restricted User
ya, thats wat i figured. i just didnt know if this would retad the timing enough for a 200 shot or if i needed to take a llittle out on the tune.
Old Feb 9, 2010 | 05:15 AM
86formula's Avatar
it will pull enough for a 200 shot, im using it for mine with a 200 shot
Old Feb 9, 2010 | 08:09 AM
mdacton's Avatar
to figure out how much timing you need you need to learn how to read your spark plugs to really dialo your set-up in
Old Feb 9, 2010 | 07:14 PM
kalebm22's Avatar
Restricted User
well i dont have anyway of tuning the engine myself. i have to get a mail order tune everytime i change something. if this will safely retard enough timing for a 200 shot then i will be content
Old Feb 9, 2010 | 07:28 PM
mdacton's Avatar
yes it will
I meant to tune the nitrous system in. there is a how to read spark plug video at racingsecrets.com you need to learn how to read the to get the most out of your nitrous
Old Feb 10, 2010 | 01:52 AM
kalebm22's Avatar
Restricted User
Originally Posted by mdacton
yes it will
oh ok gotcha. how can i tune the nirtous without tuning software? do i just change the jets or something?
Old Feb 10, 2010 | 07:31 AM
mdacton's Avatar
you can play with jet and timing. I have found quite huge gains with very very minor changes. We found 20 rwhp in my buddies car from 1 degree of timing on motor. so a really good tune up is worth alot
Old Feb 10, 2010 | 12:30 PM
kalebm22's Avatar
Restricted User
oh ok cool. i will definately try to learn how to do that.
