new motor no start
for starters get headers on the motor, if they are, then no worreis on then check the basic stuff. i have seen people who fire their stuff with no exh. manifolds, that is plain stupid! one purpose of the headers is to draw heat away, where does the heat stay with no headers on..... in the head, specifically on the valves.
are wires routed to correct plugs, are all connections made ie, map, tps, iac, iat, opti, etc....
it is probably something simple
Coil wire hooked up?
Opti Harness plugged in?
Timing could be it...
We had a similar issue on my buddies car and come to find out the rotor in the opti had ground against the cap and was sending spark to the wrong cylinders at the wrong time and it would spin over for a second then stop like the battery was weak....
Check all your grounds really good too!
Give us a little more info on what its doing.......
