Sputtering at high RPM
car has 108,000
Car has a rough idea due to exhaust leaks which i need to get fixed. Before that it would run great all the way too about 4800 and start surging and not want to shift... Believe it might be the tune. Or maybe a fuel issue? All new ignition including opti.I have no idea what it could be it has hard starts in the mornings so im thinking fuel. Maybe one of you guys had this problem before. Thanks
car has 108,000
Im having the high rpm miss just like you man. Difference is that mine starts good in the morning. I have replaced EVERY sensor on this engine. Im in the process of replacing my fuel filter and Fuel pressure regulator.
I had the same type of problem before I took my engine out for a new build but When I turn the opti upside down it ratles so I think that may have been my problem, but I still have to pull the cap and see what is moving around in there. Oh and I had no codes either but thought I would ask anyway. Also a 97 car.
