valve cover question
Old Feb 11, 2010 | 03:01 PM
litch2004's Avatar
Originally Posted by ls1adamls1
has anyone seen this how to write up? i think when i get the valve covers ill try this before i go get a relocation kit.
http://www.lt1engine.com/tech/how-to...-valve-covers/
This modification is for flat valve covers so more clearancing will be needed to clear the covers that come to a point at the bolting surface. Also you do not have to have a relocation kit for the alternator if you no longer have a/c. Not sure if you do or not. But if you do not and would like any info on a how to i would be more than will to help you out on how to modify the factory bracket.
Also the bracket made to bolt the upper bolt of the alternator was made from the material cut off the upper section of the bracket.
Old Feb 12, 2010 | 10:54 AM
ls1adamls1's Avatar
yeah my ac is gone and im always open to helpful tips
Old Feb 12, 2010 | 05:45 PM
litch2004's Avatar
well just let me know. I still have most of the pictures that I can send to you. Im pretty sure Tuckin20's went off of my advice and pictures and his turned out vevy well. He is currently still running it on his car right now.
Old Feb 14, 2010 | 07:40 PM
ls1adamls1's Avatar
ttt need help moding my bracket
Old Feb 14, 2010 | 07:51 PM
DopdBrd's Avatar
A little off topic, but I'm just wondering, is it necessary to have a breather on both valve covers? My car came with different valve covers and there is only a breather on the passenger side.
Old Feb 14, 2010 | 08:19 PM
jaycenk's Avatar
There is a vent in the bottom of the LT1 intake that routs from the lifter valley up though the intake to the PCV port on the driver side. This then gets routed back into the intake through the engine as well as the ones on both of the valve covers. Venting the valve covers well enough will keep that toxic oil mess from going back in to the engine is the best way to keep the intake and runners clean as well as those exhaust recirc gases. You can use 1 on one side or 2 on one side or 2, one on either side as long as you can vent the lifter valley through the head gaskets and oil returns in the head on one side well enough to not build up pressure.
Old Feb 14, 2010 | 09:40 PM
z_speedfreak's Avatar
some one told me breathers let in un-metered air... BS right?
Old Feb 14, 2010 | 09:42 PM
jaycenk's Avatar
If it is unbafled yes it can, but if you run a baffle or a PCV it wont.
Old Feb 14, 2010 | 09:53 PM
baffle like the same 1 on the underside of the stock VC's?
Old Feb 14, 2010 | 09:59 PM
jaycenk's Avatar
yup the aluminum bowties I got for christmas have a baffle on each and then one has a baffle and open filler hole.
Old Feb 14, 2010 | 10:35 PM
DopdBrd's Avatar
Yeah, my catch can is hooked up in between the hose that comes off the front of the intake and the pcv valve. I just recently took off the "breather" that was on the passenger side and replaced it with a regular breather then capped off the line going into the throttle body. trying to clean up the engine bay.
Old Feb 15, 2010 | 07:04 PM
  #32
litch2004's Avatar
The dual filters was just a personal preference. Both covers were blank and like stated, I have internal baffles on both of them. I will be welding on AN fittings and running them to a catch can. But all in all was just a personal visual preference.
Old Feb 15, 2010 | 11:12 PM
  #33
ls1adamls1's Avatar
do i have to run internal baffles? im running the baffled grommets.
Old Feb 15, 2010 | 11:13 PM
  #34
ls1adamls1's Avatar
and thank you litch for the desription and pics of the modded bracket, you saved me.
  #35
litch2004's Avatar
this is the same thing i am running. I know many people running the same thing without any issue.
Old Feb 15, 2010 | 11:14 PM
  #36
litch2004's Avatar
did you get the PM with the other information?
Old Feb 15, 2010 | 11:17 PM
  #37
ls1adamls1's Avatar
yeah i did thanx a bunch man i really do appreciate it. ill be modding it within the next week during the cam install. ill take pics and post them up.
those desriptions halped out alot
Old Feb 15, 2010 | 11:21 PM
  #38
litch2004's Avatar
good glad I could help. Good Luck
