oil pan windage tray
mine has lasted me quite a while with stock 2 bolts.....ten years now. same bearing been it it now almost 4. Sure its not the best but I wouldnt waste my money in it til it bust
Yes, a windage tray is a must! i went through the same thing when i rebuilt my engine. and Why would you not run ARP everything??? i replaced main cap studs, connecting rods bolts, head bolts and even cam and oil pan bolts with ARP products... if your in there. why not do it once and not have to worry about it ? peace of mind is priceless...
peace of mind is worth the extra $100 or so in parts...
we all hav eour own opinions. mine is to build it once and not have to wory about it. but i understand where your coming from if the machine works already been done. the stock bolts are good. just have to worry about the conecting rods bolts for a little street engine. next time OP buy what you need first
This is not really the point though. The machine work is done so changing bolts may cause the caps to be off and wipe out bearings and crank. I agree with you I love arp stuff and never any worries but I made that mistake by having the machine work done with stock bolt but I am just building a little street motor so I don't really care. Love the ARP head bolt though.
you can re-use the 3 long studs for windage tray or buy the Miloden set.
you do need the windage tray.
If you did a stroker....1/8" washers under tray on studs and oil pump bolt will raise it enough to clear rod bolts.
