Ls injector in LT1
I know someone has tried this, does it work? I tried the search and couldnt come up with anything. I have a set that was given to me so not like it would cost me anything but time. They look to be a little shorter?
My car actually has LS1 injectors right now.. They work great. The reason I got LS1 injectors was because I had a set that I got for cheap, and my old LT1 injectors were super clogged... All i did was shave the fuel rails just a tad, and placed bigger o rings on the tips of the Injectors so that they will seal right with the intake.. And ofcoarse, got a tune.. Plugs are the same.. EV1
How can this question be answered accurately?
OP did not state what version of LS; LS1, LS2, etc.
LS1 injectors rated at 28# at 4 Bar will flow right at 24# at 3 Bar and the connector is the same.
It is also unknown what the target vehicle is, 93, 97, etc.
Since injector sizes in LT1s varied from 22# to 24#, this is also important information.
I have a set of injectors set up at 280 Bar...?
Kidding aside, your looking at 6 in one hand and 1/2 dozen in the other.
-Dustin-
-Dustin-
ok guys it a 94 formula and 98 LS1 injectors. So i see that they will work but am i reading it right that they do pretty much the same because of the fuel pressure? Guess i should just quite being cheap and get some 30lbs injectors.
