Best location for MSD 6AL box
Old Feb 16, 2010 | 02:58 PM
koolaid_kid's Avatar
Default Best location for MSD 6AL box
I will be installing a 6AL this spring. Since my car is a sleeper, I would like to place it out of the way (hidden, like everything else). I saw another thread where the PO put it under the console in the cabin. Would that get hotter than a unit placed under the hood next to the heat of the engine? What about heat sinks and fans to help cool it, such as those used to cool CPUs?
I saw a race car a couple of years ago where the box was sitting on the dashboard, far away from the engine. Not real pratical for me, but it shows they wanted it away from the heat of the engine.
Old Feb 16, 2010 | 03:20 PM
bigj2717's Avatar
They need to have plenty of air circulation so i would not put it under the console. Somewhere in the engine bay thats open is a good spot
Old Feb 16, 2010 | 03:24 PM
wllbndthrw's Avatar
not really hidden but it's out of the way and easy to get to
Old Feb 16, 2010 | 06:02 PM
z_speedfreak's Avatar
heres mine
never seen it get wet and gets plenty of air
Old Feb 16, 2010 | 06:06 PM
NSTIGATR's Avatar
Originally Posted by z_speedfreak
heres mine
nice location! my digital 6 is under the cowl panel where the hvac used to be. will get a pic tomorrow.
Old Feb 16, 2010 | 06:19 PM
1redta's Avatar
I put mine under the fuse block on the driver side wheel well. Its been there for 5 years
93v8clone's Avatar
mines right under the hood behind the fuse panel and under the fuel lines ,just gotta watch where ya mount it as the hood strut can interfere with it and the fuel lines .also put some plastic conduit around the fuel lines just so they dont rub threw keeps wiring nice and short ,neat
Old Feb 16, 2010 | 06:25 PM
Z28Camaro30Ann's Avatar
^ or just get the Speedinc LT1 fuel line relocation kit! lol
Old Feb 16, 2010 | 08:02 PM
93v8clone's Avatar
^^^^^^ link please ? never heard of it
Old Feb 16, 2010 | 08:06 PM
http://www.speedinc.com/catagory.cfm?catagory=Fuel / Cooling
It is the very first item on that page. They just finished making it not too long ago. I am doing my conversion in a couple weeks!
Old Feb 16, 2010 | 10:27 PM
I really appreciate the creativity discussed here. I work in the electronics field, so placing a supposed heat-sensitive electronic device in an area that generally runs about 180 degrees or so (+/- some degrees), with passive cooling, makes me shiver.
In the air flow, away from the heat-generating device, passive cooling makes sense, as well as in a controlled environment (cabin) with passive cooling, as does hidden with active cooling (heatsinks/fan) in a controlled environment. The goal, unless I am missing something, is to keep the box at the lowest temperature possible. Some empirical evidence would be nice to have, but probably not forthcoming.
Old Feb 17, 2010 | 09:20 AM
I'm going on 6yrs w/ the msd behind the hood latch, no problems
Old Feb 17, 2010 | 09:29 AM
camar0corey's Avatar
I stuck my 6a to the right of my CAI, if you were looking at the car from the front. I'll clean up the wiring sometime down the road though when I do ABS delete and some other stuff. I could have shorted the wires quite a bit.
Old Feb 17, 2010 | 01:54 PM
I like that location a lot. Did you make the brackets yourself? They look like aluminum bar or strap, if I see them correctly.
Old Feb 17, 2010 | 06:39 PM
yep, can't remember if they were 5" or 6" strap, put 2 90* bends w/ an inch between em so it clears the latch.
Old Feb 17, 2010 | 06:51 PM
LT1's Avatar
LT1
Ive posted it before but here is mine again, you cant really tell its there. Never had issues with it, been on there for years.
Old Feb 17, 2010 | 08:51 PM
That's where I have mine, but instead of up I have it flat. Been there since 2004.
