How do you port a Throttle Body ?
Once they are bored out, larger blades are installed.
or
go to this archive and find the Throttle Body Porting Link and download the how-to
http://www.bowlingss.com/LS1_How_To.htm
or
ported tb stuff is for Ls1 style motors
Lt1 just get larger tb IE:52,54,58mm and of course the mono blade
typical mods do not require the use of a larger than stock TB I do believe 6spd cars respond to bigger TB better,thats my experience.
You can smooth the TB, but porting will require new blades.
Some of the castings can be ported to 54mm, even then you have to offset the throttle bores so you don't breach the upper vacuum port that runs from the passenger side valve cover to the upper fitting on the TB. I've ported many LT1 throttle bodies and the majority can only go to 52mm SAFELY. I stick to 52mm because at 54mm the casting walls are very thin, around .030 or less in some areas, with it being cast aluminum it can fracture easily. The last thing I would want is one of my throttle bodies failing and damaging someone’s engine. Also most intake manifolds have 52mm openings which allows for the throttle body to be bolted on without touching the intake manifold.
