Can I remove all the PCV's
Old Feb 19, 2010 | 01:11 PM
jaycenk's Avatar
Default Can I remove all the PCV's
OK just finishing up my 383 build and I want to remove all the PCV's and do breathers. I don't have emissions here and I don't want this new engine having the same bad habit as me breathing in that crap and gunking up the intake and heads. Can I remove all 3 (one on each valve cover and the one on the intake) and use one breather on each valve cover? I was planing on using a brass plug on the front of the intake and a ruber plug on the driver side of the intake. The valve covers I have do have baffles on each and the hole with gromet in it messure 1inch wide. Any reason I can't do this? I have already deleted the EGR crap as well. I thought about using High temp RTV on the bottom of the intake where the gases come up through the intake under that deflection cover but not sure if thats a real good idea. any thoughts on that?
Old Feb 19, 2010 | 01:16 PM
the_merv's Avatar
Veteran: Air Force
I would try to get some kind of Vacumn in the Crank Case..that's just my opinion..
Old Feb 19, 2010 | 01:25 PM
jaycenk's Avatar
Why? You think I should keep the one on the intake? or one of the valve cover PCV's?
Old Feb 19, 2010 | 01:34 PM
bigj2717's Avatar
I kept the one on the intake and got rid of the one on the passenger valve cover
Old Feb 19, 2010 | 01:39 PM
draggin97s10's Avatar
i did aswell.
Old Feb 19, 2010 | 01:47 PM
RamAir95TA's Avatar
Let me get this straight. You want to remove the PCV system, the system designed for removing moisture and blowby gas and vapor, entirely?
Not a good idea.
Not to mention, half of the people on this forum don't even know what a "PCV" is. The system as a whole is the PCV system. PCV stands for "positive crankcase ventilation," and is not specifically one component. There is a PCV valve, a PCV fresh air supply hose, and a PCV return hose. There is no such thing as "all of the PCVs" and whatnot. Each part compliments eachother. Manifold vacuum pulls fresh air in from the PCV fresh air supply hose (on the passenger side valve cover) to displace stagnant contaminated crankcase gas through the PCV valve (located on the driver side of the intake manifold - there is ONLY ONE PCV VALVE - THERE IS NOT A PCV VALVE ON THE PASSENGER SIDE VALVE COVER). This gas is subsequently reintroduced into the intake manifold via the PCV return hose (either a loop on early models or a hose that is routed under the throttle body on later models) to be combusted through the normal combustion process.
Eliminating the PCV system entirely will completely seal off the crankcase, promoting sludge and retaining moisture in the crankcase. Even before the PCV system was invented, engines used a draft tube (way back in the 60s). If it was invented in the 60s and has been on every single production engine since then, it's got to be important.
Short version - if you want to delete the tube on the passenger side valve cover and replace it with a breather, that's fine. But if this engine sees ANY kind of street time, all of the other PCV components need to stay intact and functional.
Old Feb 19, 2010 | 02:23 PM
i do agree with this tho
Old Feb 19, 2010 | 03:29 PM
cumminsram06's Avatar
As a side note on how important getting those gasses out of the crankcase are, I believe most Pro-Mod cars as well as other extremely high HP cars run a completely independent vacuum pump/system to forcefully remove any air trapped in the crankcase. If hardcore race cars are still using a PCV type of system than I'm sure it's just not for looks for to make the hippies happy.
Old Feb 19, 2010 | 05:27 PM
jaycenk's Avatar
Not a good idea.
Did not understand the PCV system that way, so thanks for the intel. You are right for some reason I thought the 90 on the passenger side was a PCV valve, and that there was one on the driver side but there is not. Ok I will see if I can find replacment hose and what not to rebuild it.
By Brett Foote | 2026-06-04 05:00:17
