Need a little help please.
Old Feb 19, 2010 | 05:22 PM
stburgpete's Avatar
Question Need a little help please.
Anybody know what would cause a spike in idle on a 94 lt1? Sometimes it does and will not stop and sometime it does not do it at all.
Old Feb 19, 2010 | 05:24 PM
djjab57's Avatar
could be a few things, maybe the TPS or a vacuum leak
RamAir95TA's Avatar
A high idle is a common side-effect of a vacuum leak. A bad or dirty IAC will also cause a high idle.
Old Feb 19, 2010 | 05:25 PM
RamAir95TA's Avatar
The TPS can't set a high idle. If the TPS was bad or out of range it'd set a code.
Old Feb 19, 2010 | 05:26 PM
stburgpete's Avatar
Tps just replaced vacuum leak fixed.
Old Feb 19, 2010 | 05:28 PM
stburgpete's Avatar
Still got high idle. If it was the IAC wouldn't it do it all the time?
Old Feb 19, 2010 | 05:31 PM
stburgpete's Avatar
High idle is there yes. If it was IAC it would cause a spike to?
Old Feb 19, 2010 | 05:59 PM
stburgpete's Avatar
Is the spike do to high idle to anybody know?
