Problems? Overheated top end rebuild
I am looking to buy a 95 z28. Everything appears great... the car runs just fine, makes really good oil pressure, doesnt smoke at all. However, the seller said that they recently replaced the opti. When they put everything back together, they reversed the cooling from the radiator that goes to the heads. He drove the car for a minute and basically starved the top end, which warped the heads, creating a head gasket leak.
They then pulled the motor, got the heads machined (supposedly they are now in very good shape), but when they put it all back together they used all of the same parts, including the same head bolts. I would not have been able to tell this had he not told me about the issue.... as everything seemed great. Idled at 20 psi, and at WOT made 50 psi.
I like pretty much everything about the car, but this issue bothers me. Is this rebuild pretty much a big no-no? Does it sound like they were thorough enough in their rebuild to ease my conscience?
On another note... the interior has seen better days. The headliner is loose and the driver seat is ripped and sewn. However, has new tires, brakes, alternator, water pump, opti, and new seals. Basically, I would have bought the car on the spot had I not know about the issue with the rebuild.
If it runs fine it runs fine. But if it makes you feel more comfortable and if you have the time, money, and resources to pull it all apart and replace both head gaskets with new bolts, go for it.
You can re-use the LT1 Head Bolts, they aren't the TTY Bolts like the LS1's.
If everything was running good and it was staying around the 190-210 area then I don't see anything wrong with it.
I wouldn't pay no $3500 though..maybe $2700..$3k max.
. Thanks for the help tho guys.
