what headgaskets?
Old Feb 20, 2010 | 03:38 PM
kalebm22's Avatar
Restricted User
Default what headgaskets?
i purchased the full srp gasket kit off summit for 175. but my question is will the head gaskets in this kit support 12.3 to 1 compression and atleast 200hp shot of no2?
if it wont then what head gasket would you recomend?
Old Feb 20, 2010 | 03:58 PM
Z28Camaro30Ann's Avatar
What is the thickness and bore size of those SRP Head gaskets? Have a part number?
If you wanna get high compression you need a thin head gasket with smaller bore size. Cometic can custom make a .027 thickness head gasket with your bore size such as mine would be 4.040, but they cost about 100 each...
Mr. Gasket is the brand I used because they are the next best and ALOT cheaper. Mr. Gasket has the smallest pre-made with .026 thickness, 4.100 bore size...
Old Feb 20, 2010 | 04:00 PM
with my LE2 heads, -4cc pistons, and Mr. Gasket head gaskets I should be somewhere around 11.5 to 1 CR
Old Feb 20, 2010 | 04:11 PM
kalebm22's Avatar
Restricted User
im not sure what the part number is, i am more or less just looking for what headgasket will hold up to high compression and nitrous on my 383. i ran the mr gasket on my stocck bottom end and it worked good but i dont know if they will hold nitrous or not
Old Feb 20, 2010 | 04:13 PM
What thickness is the gasket, do you know?
Old Feb 20, 2010 | 04:22 PM
kalebm22's Avatar
Restricted User
well im thinking its .036 but im really not sure. it is egg shaped holes for the pistons.
Old Feb 20, 2010 | 06:27 PM
RamAir95TA's Avatar
You're talking about gasket thickness in the thousandths of an inch, which translates into SCR in the hundredths of an inch. There is no measurable performance difference in dynamic compression from a .026 to a .027 gasket.
Fact is, either one of those gaskets will work fine. Stop worrying about your static compression also as it means jack squat.
FWIW, I use the Impala gaskets at .028". Tried and true.
Old Feb 21, 2010 | 01:01 AM
Wicked94Z's Avatar
since its a 383, i'm assuming his deck height will be different than stock, and not have the pistons .020 in the hole. I'd say this is pretty crucial when selecting a head gasket, can't have the quench too tight. my pistons are .007 out of the hold, with a .040 compressed MLS Gasket 4.100 bore. Don't want your quench much tighter than that...
Old Feb 21, 2010 | 03:34 AM
kalebm22's Avatar
Restricted User
wat are you talking about? when did i ever say anything about my compresison. if you read the posts i want to know if there is a betteer nitrous head gasket or something that will handle quiet a bit of compression. im not worried about every last thousands on the compression. i really just want to know wat a good nitrous ready gasket is. thanks.
Old Feb 21, 2010 | 04:28 AM
Wicked94Z's Avatar
how do you know you're compression ratio without knowing deck height and gasket thickness, assuming you know what your piston dish/dome volume is and chamber cc... deck height dictates gasket thickness to acheive the correct quench, which is CRUCIAL when running high compression on pump gas. A cometic gasket is the best for nitrous, but your heads and block better be perfectly flat, you can order them any thickness you want, but they're kinda spendy.
Old Feb 21, 2010 | 11:26 AM
kalebm22's Avatar
Restricted User
yeas i ccan get get the piston and deck height i need to set my compression ratio and quench where i want it. i just needed to know what gasket i needed before i could figure that out. would the mr gasket gaskets work? i really liked them and lloyd recomended them to me for my head and cam package on the stock motor
Old Feb 21, 2010 | 11:30 AM
RamAir95TA's Avatar
It would make more sense to select a head gasket thickness when you know your finished deck height and CC volume.
Old Feb 21, 2010 | 02:17 PM
kalebm22's Avatar
Restricted User
i can do that to, by wat u guys are saying any headgasket will work for high compression and 200+ nitrous? if thats the case then it will make things alot easier, i just find that hard to belive
Old Feb 21, 2010 | 02:21 PM
RamAir95TA's Avatar
I have high SCR and DCR and plan on a 150-200 shot on my 383, and I'm using the Impala HGs.
Old Feb 21, 2010 | 03:11 PM
kalebm22's Avatar
Restricted User
ok thanks, thats what i was needing to know
