which would you do??
Old Feb 23, 2010 | 08:47 AM
1BAD_LS1's Avatar
Restricted User
Go option 3... but take it to a fabrication shop.... they will make sure it is straight... and that is relly important.
Old Feb 23, 2010 | 03:58 PM
Z28Camaro30Ann's Avatar
Ok, so do i need to tune my car AFTER the new rear and new gears, or BEFORE, or does that even matter??
also does anyone have a template or write up about making a custom torque arm mount for an 8.8" rear end?
Old Feb 23, 2010 | 05:41 PM
RamAir95TA's Avatar
Just install the tune when you put the rear in. Are you going to load it yourself?
I highly doubt anyone has a template available...
Old Feb 23, 2010 | 05:45 PM
I will have a little bit of help with the install, but as for the build of the rear someone else will be doing the welding and all.
Does it "matter" if I tune before the rear instead of after or no? I am just curious if it does and if so why for my own education. Thanks guys!
Old Feb 23, 2010 | 05:51 PM
duh's Avatar
duh
Only thing you really need to "tune" for is the gear. You can do that at any time, but it will cause your speedo to be off until that gear is actually in the car. It really won't hurt anything if you do it before or after the actual install.
Old Feb 23, 2010 | 05:53 PM
Got it, cool. So if I wanna have me speedo on and all, do it AFTER the install. If I tune it BEFORE the install I will need to have the tune edited to fix my speedo correct?
Old Feb 23, 2010 | 05:57 PM
RamAir95TA's Avatar
If the tune isn't matched to the gears, depending on a few things, you might get some early or late shifts. It won't hurt anything so I wouldn't hesitate to drive around.
Old Feb 23, 2010 | 06:06 PM
cool, thanks buddy!
Old Feb 23, 2010 | 08:05 PM
gregrob's Avatar
Its a 6 speed...
Old Feb 23, 2010 | 10:10 PM
RamAir95TA's Avatar
Originally Posted by gregrob
Its a 6 speed...
:hangs head in shame:
Old Feb 23, 2010 | 10:41 PM
gregrob's Avatar
lol..
