Datamaster Results
So I sent a copy of the datalog to Solomon of LT1pcmtunning.com and he told me I had a bad O2 sensor on the passenger side, numbers were all over the place, and an error code 26 for the CCP system.
I've looked all over and found the CCP system has something to do with capturing fuel vapors, is this a neccessary system to keep? It has a solenoid on the passenger side of the intake manifold I believe and some vacuum lines running off of it. Is there a way to remove it and keep everything happy? It seems like a possiblity to remove some clutter under the hood and cap off some possible vacuum leaks?
Oh and the funny thing is the CCP code should have thrown the check engine light but mine is not lit, I think the previous owner pulled the bulb for it in the dash, what a tool! Lets pull the bulb for the check engine light instead of fix the problem! Mouth Breathers, I tell ya!
