March Engine Build!!!!!
Old Feb 23, 2010 | 06:23 PM
old93camaro's Avatar
Default March Engine Build!!!!!
so guys/gals this is my engine build that i will be doing starting march tell me what you think and remember I ALL READY Bought PARTS.
lt1 383 with forged scat crank and 6' I-beams
5.4 forged flat top wesico pistons
LE2 heads with 918 beehives and the other stuff
XFI 280 comp cam
42lb green top svo
1.6 scorpions race rockers
.head gaskets are Bore: 4.040" Compressed Thickness: .051" to keep CR down to around 11:5-12:1
that's all i can think of right now...how do you think this will run. Your constructive bashing is needed may change up a little depending on answers
Old Feb 23, 2010 | 06:29 PM
RamAir95TA's Avatar
What CCs are the heads?
Old Feb 23, 2010 | 06:33 PM
52-54cc may have to get them checked because i may change the springs that are 918 to something else but i think there 52cc at least that's what i was told.
Old Feb 23, 2010 | 06:36 PM
duh's Avatar
duh
If you're running the 52-54cc heads your CR hould be nice and low with .051 compressed Head gasket and a 5.4cc dish pistons......what's the piston to deck clearance?
Old Feb 23, 2010 | 06:37 PM
RamAir95TA's Avatar
Originally Posted by duh
they must be tiny if he's using a .051 compressed hg to keep the compression in the 11.5-12:1 range. That's gotta be like a 48 cc head......especially with a 5.4cc dish piston (if I'm reading that right). Other than those numbers I don't see too many problems. I personally would have gone with a flat top with valve reliefs and the .040 cometic gasket with the LE2 (with a little more chamber volume) and made some decent NA power, and still keep the compression down.
That was my concern too. A .051 head gasket is pretty damn thick.
Old Feb 23, 2010 | 06:39 PM
duh's Avatar
duh
you guys are too fast, I changed the post cause he responded
Old Feb 23, 2010 | 06:55 PM
sorry for the miss understanding they are 5.4 flat top valve reliefs.. i wanted to make sure it ran on pump gas with no problem
http://www.summitracing.com/parts/WIS-K061A3/
Old Feb 23, 2010 | 08:21 PM
now that we got the ok with the build do you think it can put down atleast 390-410 to the wheels
Old Feb 24, 2010 | 06:37 AM
duh's Avatar
duh
according to this your SCR will be right at 12:1 if the pistons are .005 in the hole. Now that being said, instead of the XFI280, maybe talk with LE (since you already have his heads) and see what he says to make your goal at the tire. Chances are you're going to want to stall an A4 to have any kind of driveability. If you've got an M6 then slap a gear in it and you should be well on your way. Truthfully I think the cam is a little small. I understand you already have it, but with the stroker that cam will seem even smaller. I personally would go with a custom or even an GM847 (I'm partial to it, as I had one in my old car). With the better heads and more cubes it will definitely help to have a larger cam. This is just my personal opinion, but do what feels right, not only in your mind, but in your pocket book
Old Feb 24, 2010 | 07:51 AM
94Z28rag's Avatar
That's a very mild cam for a 383, IMO, but should get you close to your power goals assuming the rest of the build is carefully put together.
Old Feb 24, 2010 | 08:14 AM
slomarao's Avatar
I would do a custom cam.
Old Feb 24, 2010 | 08:17 AM
the real reason I went with the xfi 280 is because I want to get use to the power and likeable before I went bigger...this summer I will be getting a custom cam from LE for track time. yes the car is a m6 and I plan on going with some 373 soon as well
Old Feb 24, 2010 | 08:50 AM
duh's Avatar
duh
Personally, I'd build once rather than twice. Learning to handle the power is more of a discipline than a lesson. All it takes is a little less movement of the right foot. I'd go big the first time, that way you don't have to pull it out and spend all the extra $$$ in new gaskets on a new motor. Again just my opinion, but I like doing things once not twice.
Old Feb 24, 2010 | 09:40 AM
yea i know but thanks for the help duh and ramair95 when i get it running ill put up the dyno numbers after break in
Old Feb 26, 2010 | 05:27 PM
Got some bad news form JEGs today told me my head gaskets want be he until march 26 damn guess i have to look at plan B now
Old Feb 27, 2010 | 06:12 AM
duh's Avatar
duh
check summit and see if they have them, there are always other options.....
Old Feb 27, 2010 | 09:25 AM
yea i checked summit they dont have them on there website but im going ot give then a call and see if they can get it
Old Feb 27, 2010 | 09:35 AM
Coltf1991's Avatar
whats the part number on the gaskets? What brand? What is the material?
Old Feb 27, 2010 | 10:09 AM
aboatguy's Avatar
I wouldn't go so thick on the head gasket(you would probably have better driveablity on pump gas with a tighter quench IE less propensity for detonation) even though it will add a little static compression bump? Most experts recommend SBC quench of .045 or less) I'm running .032 on my LT1.... pistons .005 in the hole and .027 cometics. Even with Static compression a little above 12.1:1 the engine has been doing fine on 91-93 octane for a couple of years (Its my daily driver and sees all kinds of weather and traffic conditions and when I get the chance I beat it like a rented mule)
Mike
Old Feb 27, 2010 | 11:37 AM
The gaskets are cometic MLS here is a link to them
http://www.jegs.com/i/Cometic+Gasket...5-051/10002/-1
people keep saying .051 are to big but stock are .050 but I'm thinking of going with the .045 if the .051 take to long... I just don't want a problem running pump gas in the car
