banjo bolt on crossover tube
Old Feb 26, 2010 | 07:01 AM
97pontta's Avatar
I also made my own cross over last winter. Mine was broke between the banjo bolt blocks but OK from the block that ran to the rad. I just tapped each block for 1/8 NPT and went to the hardware store to get the proper brass fittings. Stopped at the local auto store and got the proper hose, assembled them with thread sealant. No leaks or problems yet. The one thing you have to be careful of is when tightening the banjo bolts they want to rotate the coolant blocks, you just have to get a set of channel locks in there to keep the block from rotating while tightening.
Old Feb 26, 2010 | 08:25 AM
the_merv's Avatar
Veteran: Air Force
I went to Lowes and made mine..
Old Feb 26, 2010 | 09:32 AM
speedracer2536's Avatar
how did yall make yours? im a visual person i need pics and write up lol
Old Feb 26, 2010 | 09:59 AM
the_merv's Avatar
Veteran: Air Force
If I can find the pic I had I would post it.. it was just 1/2" NPT Brass Fittings, a couple of Elbows, a T, some Teflon Tape, and some 5/16" and 3/8" Rubber Hose. It worked like a champ.
Old Feb 26, 2010 | 10:11 AM
Puck's Avatar
There are pics and an explanation in the link I posted.
Old Feb 26, 2010 | 10:17 AM
the_merv's Avatar
Veteran: Air Force
I found em in the search..they are from like 3 years ago..lol
They worked great..easy to remove, and never leaked.
Attached Thumbnails banjo bolt on crossover tube-modified-steam-linea.jpg   banjo bolt on crossover tube-modified-steam-line2a.jpg   banjo bolt on crossover tube-modified-steam-line3a.jpg
