Crankshaft seal
Old Feb 26, 2010 | 07:35 PM
95BlkBird's Avatar
Default Crankshaft seal
How hard is it to replace the front crankshaft seal? Haynes says you need to pull basically everything off the front but it doesn't look like you would need to. Trying to save myself some extra work lol. TIA
Old Feb 26, 2010 | 07:52 PM
bigj2717's Avatar
All you should need to take off to get to the one on the front of the timing chain cover in the belt, crank pully, and the crank hub. I never really paid attention if the opti is in the way at all but if it is then you also need to pull the water pump and opti
Old Feb 26, 2010 | 07:57 PM
Badazz 97 TA's Avatar
just the belt, and the pulley/hub needs to come off. It helps to remove the fan assembly for more room with the puller. but thats it....
Old Feb 26, 2010 | 08:02 PM
95BlkBird's Avatar
Thats what I thought. Haynes says take everything off lol. Seems to be not needed but never know.
Old Feb 26, 2010 | 08:37 PM
97LT1's Avatar
You can get it off without removing distributor if thats what your asking. you just take off harmonic dampner and hub, and pull seal carefully with tool
Old Feb 26, 2010 | 08:46 PM
95BlkBird's Avatar
I have a feeling I will need to buy a full gasket/seal set because I can't find just that seal
Old Feb 26, 2010 | 09:16 PM
shbox's Avatar
GM PART # 10128316 for just that seal, but you can buy a Felpro (Part Number: TCS 45956) front cover set for probably less. National seal number is 9845 for the crank seal.
Old Feb 26, 2010 | 09:56 PM
95BlkBird's Avatar
Awesome tyvm. Im gonna just buy the set so I have them anyways. Thanks again
