low coolant level sensor and retaining clip....
Subscribe
Feb 28, 2010 | 11:21 AM
is there a right way or direction to put the clip on?
Mine keeps popping off after a radiator change.
Well, this is actually the second time, but I haven't driven the car in the last 5 months because of a headgasket issue.
Reply 0
Feb 28, 2010 | 07:31 PM
anyone? put it in like an upside down u (from the top) or normal U from the bottom?
Do I need a new clip?
Reply 0
Feb 28, 2010 | 10:15 PM
My rads out of the car at the moment. I'll go look right now and see which way it is suppose to be.
Reply 0
Feb 28, 2010 | 10:21 PM
If the rad is in the car and your standing in front of it the metal clip should be like this C so it looks like the letter "C" and the electrical connector goes in at the bottom.
Reply 0
Feb 28, 2010 | 10:42 PM
Check the O rings on the level sensor You may need to change them and also make sure that the clip is hooked around the left and right sides, top and bottom and that the clip is straight. It is supposed to hook it's self on the flange on the radiator port. make sure that flange is not broken.
Reply 0
Feb 28, 2010 | 11:46 PM
Thank You guys, that's a great help.
I'll have to check for those O rings, I hope they're OK; if not, I hope a replacement can be had easily.
Reply 0
Mar 1, 2010 | 06:28 AM
I don't run one and it's plugged off..do you rely on it?
Reply 0
Mar 1, 2010 | 09:43 AM
well it has been useful, and it is working. I've been having the longest issue w/ a head gasket so it has been useful. Do I rely on it no.
So, how did you plug it up?
Reply 0
Mar 1, 2010 | 09:59 AM
My sensor went **** up, so Im just plugging the hole with the old sensor. I just didn't connect the harness up to it.
Reply 0
Mar 1, 2010 | 10:28 AM
I bought a new Radiator and never messed with it..it has a plug there.
Reply 0
Subscribe
