Tranny Swap
Old Mar 1, 2010 | 02:36 PM
95_TA_USMC's Avatar
Default Tranny Swap
im having difficulty... can i just install the new plugs and not rip out any auto wires? this **** is crazy i think it can be done, but i just cant seem to figure out what to do with all these wires? serious help is needed
Old Mar 1, 2010 | 02:45 PM
RamAir95TA's Avatar
What?
Old Mar 1, 2010 | 02:46 PM
the_merv's Avatar
What you mean..what wires you trying to install?
Old Mar 1, 2010 | 03:01 PM
95_TA_USMC's Avatar
well merv i have tried to use you write ups as an installation guide, and i cant follow the wiring? everything else is done just wires in the car, and im tryin to figure it out...
Old Mar 1, 2010 | 03:04 PM
RamAir95TA's Avatar
No one know what you're trying to do!
Old Mar 1, 2010 | 03:05 PM
LSWHO's Avatar
sounds like he's swapping trannies and needs help on the wiring aspect.
JB_97ws6TA's Avatar
I am doing the same conversion as we speak and don't get me wrong, merv's write up is great but I found another one that kind of helped fill in the blanks.
http://www.afrashteh.com/tranny_pics/T56.htm
Merv's filled in the holes that the one above has and vice versa, with these two together I feel you can train a monkey to swap out t56s in these cars.
not to mention shbox if you have some doublechecking on pcm pinouts to do which I did. If you are having a problem with a specific portion of the swap please ask and we may be able to help out if you are a little more specific.
Old Mar 1, 2010 | 03:08 PM
the_merv's Avatar
So you were able to do the Engine Harness with the directions I gave you?
The interior wiring in the Car is giving you a problem?
Old Mar 1, 2010 | 03:09 PM
95_TA_USMC's Avatar
yes im doing a tranny swap, and i have everything installed except finishing this wiring and its kickin my butt...
Old Mar 1, 2010 | 03:18 PM
95_TA_USMC's Avatar
no wiring is done yet, but maybe im thinking too much? wanna come finish it for me merv?
Old Mar 1, 2010 | 03:25 PM
JB_97ws6TA's Avatar
your swap included adding relays because you had done the ls swap but for an LT1 T56 swap all you need to do is extend the wiring that is already in the neutral safety switch over to the clutch start switch and that will function like factory. I decided to buy a weatherpack connector to add to the interior harness and I am going to extend the factory intended power and feed for the reverse lights through the harness that way i do not have to splice the power wire going to the tranny. Other than that it seems like it is snip and rip out of the engine harness with the exception of one wire to the pcm and one wire for a 12v switched and of cousr the VSS circuit.
Old Mar 1, 2010 | 03:38 PM
the_merv's Avatar
Ya mine was setup a little different since it was for the LS, but the majority of it is the same. I gave him instructions on what I thought would work for the LT1 setup based on the Schematics..I have a feeling I was close..
We sent them little banana eatin turd throwin bastards to the moon, I'm sure it's possible..
Yea..SHbox's site helps alot with the LT1 technical stuff, I pretty much got it for the LS stuff, it's very simple for the LS Cars.
I would if I could..
