BBK Under Drive Pulley
Well, lemme tell ya this.. I got the ASP under drive and alternator under drive (bad idea) , and at night lights dim like an s.o.b. if im just sitting in traffic.
If you can do it without the alt (underdrive) pulley go for it.. not sure on the belt size you would need though
So looks like i'll just try the UD pulley alone without getting an aftermarket alternator pulley first and see how that works out. I just wanted to double check that some of you guys use just the UD pulley cause i've heard some stories about charging issues if the alternator pulley is not used
Also if anyone has a belt part number I would really appreciate it. Thanks.
