Guideplates
http://www.trickflow.com/partdetail....&N=400098+150+
If so, how do I go about ordering them? I don't see it anywhere
Has anyone had problems with the TFS guideplates?
Years ago I had a set of GM plates on my bolt on motor. One day a rocker fell off of a valve because one push rod wore a slot nearly 1/8" in one guide plate. The rocker was damaged and the top of the valve face was damaged as well. I also saw a noticeable amount of wear on many of the other slots on the other guide plates. All this with less than 3K miles of use.
Bottom line is these guide plates were not hardened. I determined this by dragging a file across one and it tried to cut the surface. On a hardened plate, the file will not cut it. It will just glide across and not leave a blemish and will in fact make a totally different sound during the file test compared to an unhardened plate.
I was running Comp pro-mag rockers and 7.200" PR's at the time and the rocker geometry appeared decent so I could not detect anything that I did wrong to cause this to happen. I did use "cheap" hardened PR's but they were hardened none the less.
I bought another full set of GM guide plates and they were not hardened either. I did however harden them myself using Kasenit powder that is used to harden tooling. The powder is a mix of organic material that smells like cat **** while performing the hardening process. I heated the two slots up on the guide plate cherry red and dipped it into the powder. Did this three times and on the fourth time, after heating they were dipped in water to perform a queching process. The results before and after were night and day.
To this day and after 15K miles, there is absolutely no wear period on my self hardened guide plates. I would never run a guide plate unless its hardened period.
Take a file (like one pictured below) and just run it across an edge of one of the plates and if it does nothing to it at ALL it IS hardened? If it starts to grind away at the surface its NOT hardened?
