need help pulling motor
Old Mar 6, 2010 | 08:02 PM
tug686spd's Avatar
Default need help pulling motor
94 z28 lt1 t56. We are pulling the motor out the top because the motor was blown and we just wanted to get it out of there while waiting on parts to come in. The intake, exhaust, accesories, radiator, and everything else is out of the way. The problem is we cant seperate the engine from the trans, there is about a 1/2 inch gap between the two and that is all we could get without fear of breaking something in the tranny which we plan on useing. Is there something stupid that did not unhook that might be holding these together. I realy hope so let me know what you think.
Old Mar 6, 2010 | 08:09 PM
bigj2717's Avatar
Make sure before you try and pull the trans out that you slid the clutch fork off the throwout bearing. Unbolt the clutch slave and pull the clutch fork down I bet thats your problem
Old Mar 6, 2010 | 08:10 PM
MattSapp95_T/A's Avatar
may be in a bind if you have the motor lifted up. The input shaft on the tranny could be bound up or the clutch fork..after you get the clutch fork loose..try lowering the motor a little and using a pry bar to keep pressure....
As long as you have all the bolt out of the bell housing and and everything off the motor and the motor mounts all undone you should be good..
We had a time getting my motor and trans apart just because of what I stated above...
Hope that helps
Matt
Old Mar 6, 2010 | 08:28 PM
yonerhottlt1's Avatar
What they said........
Old Mar 6, 2010 | 08:31 PM
tug686spd's Avatar
Default clutch fork
We did not remove the the fork or slave cylinder. I hope it is that simple, never had to do that on other cars i have done before. Not going back at her tonight we will see in the morning. Hopefully the parts come in this week and we can get the other motor in next weekend. The new powerplant is a sbc 327. Thanks for the help and will let you know how we make out.
Old Mar 6, 2010 | 08:34 PM
bigj2717's Avatar
Well you might not have to do that on other cars but on lt1's for the trans to come off the clutch fork has to come off the throw out bearing
Old Mar 6, 2010 | 09:30 PM
shbox's Avatar
Classic "clutch fork still engaged" thread.
Old Mar 6, 2010 | 09:43 PM
WS Sick's Avatar
I never had problems with standard trannies til i tried to replace a clutch on an LT1...lol
But seriously, taking the motor out the top may be conveininet , but after you drop the K once you will never do through the top aagain, I like setting on a roll around seat and installing headers and not breaking my back.
Old Mar 6, 2010 | 10:05 PM
tug686spd's Avatar
I see this is a common problem glad to found the answer this is a great site. Are the ls1 clutches the same because this is my brother new project and he only got the motor because I am doing a ls1 t56 swap in my car, 68 camaro. A house and kid has had it side lined for a little bit.
Attached Thumbnails need help pulling motor-car-005.jpg   need help pulling motor-car-002.jpg   need help pulling motor-car-004.jpg
Old Mar 6, 2010 | 10:07 PM
WS Sick's Avatar
I have never done the LS1 clutch, but I understand it is completely different and easier on the 2000 and up LS1s.
Old Mar 6, 2010 | 10:21 PM
Johnny-LT1-runner's Avatar
Rockstar
Please man, save your time and nerves and drop it out the bottom, if you have the ceiling room anyways.
Old Mar 7, 2010 | 02:03 PM
tug686spd's Avatar
Pulled the clutch fork and the two pulled right apart. Thanks for the help glad to see some people even answer the dumb questions.
Old Mar 7, 2010 | 02:18 PM
the_merv's Avatar
1998-up is the F-body LS1's.. Clutches are a cakewalk..just bolt it all up and align it properly.
The LS1 is a push-type so it uses an internal Throw-out Bearing that is a complete nightmare to bleed without a Speed Bleeder..
The Cable you see here in the pic is the Speed Bleeder that is on mine..the LT1 doesn't need this.
Old Mar 7, 2010 | 10:31 PM
WS Sick's Avatar
Yes but wasnt the clutch mechinism even more improved on on the 2000 up LS1s ?
Old Mar 7, 2010 | 11:25 PM
the_merv's Avatar
The Slave Cylinder design was improved.
