LTX Shootout Rules Clarification Needed
Old Mar 10, 2010 | 10:05 AM
GIZMO's Avatar
Default LTX Shootout Rules Clarification Needed
I posted this on the Shootout site, but it has seen very little traffic. I need an answer pretty quick, before I spend a bunch of money on parts.
"Non-stock style suspension permitted with 100 lb"
What gets a penalty?
1. Where do coil over shocks fit in this?
2. What about a solid rear conversion in a Corvette, etc. The NHRA allows a torque arm in Stock Eliminator.
3. What about a F-Body suspension in another car?
4. Anything that attaches to the stock mounting points?
Just asking, because this rule is really open to interpretation.
Thanks,
Daren
Old Mar 10, 2010 | 10:10 AM
draggin97s10's Avatar
I BELeive stock style means its mounted in the factory locations
Old Mar 10, 2010 | 10:29 AM
AChotrod's Avatar
Thats what I was always told. As long as it bolts in the factory locations your golden.
Old Mar 10, 2010 | 10:37 AM
GIZMO's Avatar
I really need that question and the others made clear by the organizers.
A lot of "stock style" components do not attach to the factory locations. The torque arm is one that usually has a relocated front mount.
The no wheelie bar rule has me looking hard at the suspension. Gump cuts low 1.3 sixty foot times with 402 RWHP. Add a few more HP and I may have an issue!
I am sure that all these rules seem dumb to you guys, but I want to bring something that is considered legal in September.
Old Mar 10, 2010 | 10:39 AM
AChotrod's Avatar
So what this talk about other cars??? C4?
Old Mar 10, 2010 | 10:57 AM
GIZMO's Avatar
Old Mar 10, 2010 | 02:17 PM
i like 1.3 sixties with 402 wrhp
Old Mar 10, 2010 | 02:23 PM
GIZMO's Avatar
I wonder what it would be if I took the 250 lbs of lead out of the trunk? I hope the air is good in Rockingham in two weeks!
Old Mar 10, 2010 | 03:03 PM
96lt1m6's Avatar
GIZMO
hello my friend, the answer to your question can easily be answered by Tony Sheppard he quickly replied to my questions similar to yours.. PM him for a quick response
Old Mar 10, 2010 | 05:29 PM
Tony Shepherd's Avatar
1. Where do coil over shocks fit in this? Fronts ok with stock mounting points. Rears.....that would move the location of the springs so add the penalty.
2. What about a solid rear conversion in a Corvette, etc. The NHRA allows a torque arm in Stock Eliminator. Ok ...but add the weight penalty
3. What about a F-Body suspension in another car? Ok.....but add the penalty.
4. Anything that attaches to the stock mounting points? Correct
Thanks,
Daren
Let me know if you need more clarification.
Old Mar 10, 2010 | 05:40 PM
A lot of "stock style" components do not attach to the factory locations. The torque arm is one that usually has a relocated front mount. Front Torque arm mounting points can be moved. That is a normal change that is allowed in other series.
Old Mar 10, 2010 | 05:45 PM
Formula383's Avatar
Thanks,
Daren
I agree with Tony...
Old Mar 10, 2010 | 07:22 PM
GIZMO's Avatar
Thanks guys!
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
i'll third that.......................................... but my opinion doesn't matter in this situation lol!!!
yeah i know, back out to the garage i go! get her ready for the streets, weather is starting to turn around slowly but surely!
Old Mar 13, 2010 | 09:31 AM
GIZMO's Avatar
Your opinion is worth a lot. You have been racing in this arena a long time. My point in racing these events is to have fun. You can't have fun if you have everyone else pissed off!
If time and finances allow, I am planning to bring something pretty cool. I have self imposed limits that should put me in the middle of the pack again this year. I will point out that I wasn't close to making the most HP in Mod N/A last year (I wasn't even in the same ZIP code!!).
1. 3175 or 3275 race weight.
2. LT4 heads and intake.
3. Stock 3.48 crank.
4. Stock throttle body?
That's about all I am going to share, but I don't think that anyone really needs to worry!
Old Mar 13, 2010 | 07:29 PM
Ed Wright's Avatar
9-Second Club
In Modified: What about Pete Z bars, with the rear/upper tabs welded to the housing, instead of that big, heavy bolt-on deal of his? Rear narrowed 3" on each side & mini tubs?
Old Mar 14, 2010 | 09:40 PM
Mini tubs ....ok.
Narrowed rear....ok.
Pete Z bars.........ok as long as torque arm is still on the car.
Old Mar 14, 2010 | 10:09 PM
GIZMO's Avatar
Pete Z bars.........acts kinda like a 4 link. You added 4 mounting points to the rear suspension.........ok to use but not stock style.......add penalty. Agree?
IMO the Pete-Z bars should not get a penalty. I have run them and they show no gain over a good torque arm. Really the torque arm works better once you figure it out. All they do is take the twist out of the rear. They are no where near as drastic as an aftermarket four link or ladder bars. The same would go for the Competition Engineering "lift bars.
Old Mar 15, 2010 | 07:22 AM
I may agree with you. I researched the Pete Z bars heavily last night after I made the reply to Ed. It seems as if people that use them still keep the torque arm. I have to compare it to the guys that use a race drag sway bar which moves the mounting points on the body.
We will have a decision on it soon.
Old Mar 15, 2010 | 09:56 AM
Ed Wright's Avatar
9-Second Club
[QUOTE=Tony Shepherd;13033005]Mini tubs ....ok.
Pete Z bars.........acts kinda like a 4 link. You added 4 mounting points to the rear suspension.........DECISION PENDING
is this what you have Ed? Also is your torque are still on the car?
Tony, that is not mine, but pretty similar. I do still have the stock torque arm.
I didn't like the big heavy bolt-on rear mount Pete sells. The Stockers can't have anything welded on, Super Stock car can. I don't know that I can make that one, still need to check the 383" over and replace some parts I robbed from it to put my first SS engine together. Need to change gears too, it would never make it to the finish line with the gears this 350" needs. Lots of work and I have some health issues right not that I don't know will be cleared up by then (or ever). I'll try.
Thanks, Ed
