fuel pressure question
I had to change a leaking fuel pressure regulator yesterday and I tested it with vac line off and I have 42# at idle. Thats all good. Now I want to make sure it's right with the vac line on and off. While driving around I had about 35 to 38. When I jumped on it it would pick up from 35 or so to almost 40. and after I let off it would drop to 33 to 36#. kind of dark so I could not see exact numbers. I am going to test it again as soon as the rain stops. so what should it be reading? This is a BWM replacement not a GM so I want to make sure it's right. I am a 383 with LE2 haeds and cam with ford 30# injectors. thanks
I had to change a leaking fuel pressure regulator yesterday and I tested it with vac line off and I have 42# while driving around. Thats all good. Now I want to make sure it's right with the vac line on. While driving around I had about 35 to 38. When I jumped on it it would pick up from 35 or so to almost 40. and after I let off it would drop to 33 to 36#. kind of dark so I could not see exact numbers. I am going to test it again as soon as the rain stops. so what should it be reading? This is a BWM replacement not a GM so I want to make sure it's right. I am a 383 with LE2 haeds and cam with ford 30# injectors. thanks
Your FP is too low while driving.
BTW - I am running a pretty similar setup to you and mine holds steady even at WOT at 43.5 on the stock pump. Granted mine only has 45K miles, but should be similar.
GM spec for fuel pressure with key on, engine off, pressure should be between 41 and 47psi (43.5psi is ideal). Once the engine is running, pressure should DROP 3-10psi and slowly increase with throttle position.
When the engine is running, vacuum is applied to the fuel pressure regulator, which offsets the spring pressure in the regulator, resulting in lower fuel pressure. Fuel pressure at idle will vary somewhat depending on barometric pressure but should ALWAYS be less than KOEO.
OP, make sure the vacuum line for the regulator isn't plugged. In your situation though, it is most likely the fuel pump. Not all fuel pumps die instantly.
At hot start idle, between 31 and 44psi is fine. Pressure should smoothly increase from there at part throttle position.
At WOT the pressure should be between 41 and 47psi (not higher, not lower). Over 47psi for a prolonged period of time can set DTC 45/65.
OP, from the info in your very last post, your fuel pressure is fine.
