walbro 255 install
Old Mar 11, 2010 | 08:24 PM
andrew ws6's Avatar
Default walbro 255 install
I am going to put a walbro pump in my T/A this weekend any tips or tricks and advise would be greatly appreciated
Andrew
Old Mar 11, 2010 | 08:27 PM
JB_97ws6TA's Avatar
Do a search on here for the trap door mod and do that. I didn't want to hack up my car for some reason so I dropped the tank the old fashioned way, I will NEVER do that again. If there was a coupler on the filler neck it would be no big deal but the damn thing is solid and it sticks straight out the side. Definately cut the trap door
Old Mar 11, 2010 | 08:34 PM
BigBadWhitey's Avatar
+1 On the trap door. I dont get any more road noise then people said i would. I sealed it with silicon. Easy enough to remove and clean need i open it again!
Old Mar 11, 2010 | 09:04 PM
94Aquaformula's Avatar
im also gonna do a fuel pump this weekend debating about droping the tank or doing the trap door. I dont like the thought about cutting a hole in my car and sparks next to my tank. Dont like the thought about unbolting my rearend and droping the tank.
Old Mar 11, 2010 | 09:10 PM
stburgpete's Avatar
Thumbs up
You will like the trap door idea.
Old Mar 11, 2010 | 09:45 PM
BLK95-Z's Avatar
+2 on the trap door. Ive also done it both ways. If you have the solid fill neck its a PITA from the bottom
Old Mar 11, 2010 | 09:49 PM
JB_97ws6TA's Avatar
use a dremel with a cutoff wheel, they don't throw a lot of sparks and either way it is sealed up pretty tight up top and the evap lines are over on the side. I can tell you from experience if you don't do the trap door you are going to wish you had...I do
Old Mar 12, 2010 | 07:09 AM
kierstyn's Avatar
I have done it both ways it takes awhile to drop the tank where the trap door is quick and easy! If you decide to drop the tank try to run as much of the gas out as you can before you do the install so it wont be so heavy.
Old Mar 12, 2010 | 07:46 AM
Jazz-LT1's Avatar
+3 on the trap door mod for 2 reasons.
1. It is fast and makes the job much easier the first time.
2. If there is a problem with the pump or anything else in the tank you'll have to take everything back apart again to fix it and then you'll be REALLY happy to have done the trap door mod.
Old Mar 12, 2010 | 08:58 AM
MTBSully's Avatar
this^^^^
when i did it i messed something simple up on the pump assembly and was SO greatful that all i had to do was remove my trap door again to get to it. Plus, its under the carpet and out of view, and is really in no way structural, so who gives a $hit?
Old Mar 12, 2010 | 09:20 AM
YSILT1's Avatar
Use the sheet metal attachment for an air chisel. Leaves no sharp edges, sparks, ect. Also took me like 5 min to cut the opening.
I bought mine from Snap On, but I know Harbor Frieght or Sears would have it.
This was off my phone. Still need to finish my Dyna Mat and build a panel.
Old Mar 12, 2010 | 10:13 PM
toy96ta's Avatar
+10 on the trap door. I was paranoid about keeping my T/A unmolested so I dropped the tank. Probably took about 4-5 hours extra with all the crap to pull out and bend the heck out of the filler neck to get it out/in...
Old Mar 12, 2010 | 10:55 PM
8595transam's Avatar
I agree with everyone else. When my stock pump died I had just filled the tank up. It went out while trying to leave the gas station. I only live about a mile from the gas station so I pushed it home and cut the hole with a dremel.
Old Mar 12, 2010 | 11:49 PM
the_merv's Avatar
Trap Door here..I also used Band Clamps on the Bucket instead of re-gluing it..it makes things alot easier.
Old Mar 13, 2010 | 12:53 AM
LT1's Avatar
LT1
I did the trap door method on my 97 Firebird V6
Got a few pictures of it.
Old Mar 13, 2010 | 10:18 AM
BLK95-Z's Avatar
Holy **** man you pushed your car a mile home? I bet that sucked
Old Mar 13, 2010 | 10:32 AM
31camaro's Avatar
can you do you racetronix hot wire mod with the trap door mod?
Old Mar 13, 2010 | 12:27 PM
SS RRR's Avatar
Village Troll
That's hysterical someone would actually claim that.
Old Mar 13, 2010 | 01:36 PM
RamAir95TA's Avatar
Absolutely. There really is no difference in either setup.
Old Mar 13, 2010 | 02:24 PM
riceburnerZ28's Avatar
x10 trap door mod! Make sure when cutting the hole to cut a extra 2-3 inches or so over the fuel lines..it will make it easier to reach and disconnect the them.
