victor jr on lt1 or sbc heads on lt1???
http://www.cableartinc.com/fittings/10/pdf/hardware.pdf
The washers he got were PN: 40HAW1230 and are 30* like he said, and he had to grind them down a little to fit properly.
T/A, did you ever measure the finished angle you needed? Maybe someone can find some pre-made at the right angle to make things easier.
As far as I know, the only real modification you need to do is have a machine shop tap the heads in back to run the crossover cooling tube, and the exhasut port depeing on what headers you use. Otherwise I believe it's a bolt up and have fun, with accompyning intake as well.
