Ceramic coated headers VS Stainless headers????
you could always wrap the stainless OP, it will look like **** but they'll knock down temps and last forever
Even if my under hood temps are higher, I can not detect any negative impacts as a result of such. I have never melted plug wires, boots, air boxes or any other component due to higher header heat. I have a CAI so header heat is not going to negatively impact intake air temps either. When I raise the hood, I dont get knocked down down by what appears to be, hotter than normal temps
Considering that the stainless will last forever I don't see the point of having them coated other than to say they will maintain that consistent silver finish as opposed to the natural stainless finish that tends to range from blue to gold depending on what gets the most heat.
Coatings will tend to reduce surface temps up to 400°, although it all depends on your set up as everything comes into play when dealing with exhaust gas temps. On average we see around 300° to 350° reduction, although again sometimes more sometimes less. It’s not always about the heat reduction though! Everything that we do is coated inside and out 100%, this being done will almost eliminate the turbulence in the exhaust gas coupled with the thermal retention and even dissipation of heat will allow your exhaust to move out much quicker, allowing your engine to work less and produce more power. We are race proven and have been testing and creating for over 30years.
I've been running Jet-Hot coated Edelbrock mid-lengths on my '95 Sierra since '01. The first thing I noticed was a dramatic decrease in under hood temps from the stock manifolds. The second thing I have seen is they still look brand new! I can say that ceramic does last, no worries here.
Mark
