clutch master cylinder
hey i just checked it and the level is like very low, maybe 3 cintimeters of fluid in it. how do i fill it? it says fill to step mark but whats a step mark?? and there is this weird black rubber funnel looking thing inside the master cylinder, what do i do with that? whats the correct way to top off the fluid?
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
whew newb.... j/k....
unscrew cap, pull out small rubber condom. if you look closely there is a moulded in rib (or parting line) that runs around the inside of the moulded reservoir. fill it to just a hair below that. then put condom back in place SLOWLY in case you over filled it, excess will come over the rim of the reservoir. install cap and you are done!
easy way to see where you are at as it sits now, is remove cap and just barely lift the rubber up about a millimetre or two. you should just see the fluid below the top of the reservoir.
i hope that makes sense, really easy other wise.
