OBD 1 switch
Old Mar 19, 2010 | 01:38 AM
stburgpete's Avatar
Default OBD 1 switch
Can a OBD1 be switched to a OBD2? If so please feel free to chime in. The more info the better. I need to know everything.
Old Mar 19, 2010 | 01:43 AM
the_merv's Avatar
Why do you want to switch it?
Most people swap OBDII to OBDI.
Old Mar 19, 2010 | 04:22 AM
gregrob's Avatar
Lol @ this
Old Mar 19, 2010 | 06:50 AM
S10Wildside's Avatar
Yes, it can be done...
  • install 96-97 timing cover
  • install 4x crank reluctor and sensor
  • install 96-97 crank hub
  • install 95-97 optispark
  • install 95-97 camshaft so that you can drive the optispark
  • add OBDII data stream wire to PCM and route to OBDII diagnostic port
That's an overview anyway. The OBDI and OBDII harnesses are nearly identical at the PCM.
Old Mar 19, 2010 | 11:38 AM
stburgpete's Avatar
pcm if free and I do not have to by the program to toon someone already has the tooner and a spair pcm. He offered this to me and asked me to get a write up on it if I could if possable.
Old Mar 19, 2010 | 11:40 AM
MTBSully's Avatar
Old Mar 19, 2010 | 11:41 AM
stburgpete's Avatar
Originally Posted by MTBSully
Is it that bad to do?
MTBSully's Avatar
have you taken any kind of english courses in your life?
Old Mar 19, 2010 | 11:43 AM
MTBSully's Avatar
you misspelled
"is"
"buy"
"tune"
"tuner"
"spare"
"possible"
also, you still have not explained why you would want to convert from obd-1 to obd-2
Old Mar 19, 2010 | 11:50 AM
stburgpete's Avatar
you misspelled
"is"
"buy"
"tune"
"tuner"
"spare"
"possible"
My bad just trying to see witch is cheaper buy, toon program and cable or switch. Didn't know I was being graded on spelling.
Old Mar 19, 2010 | 11:56 AM
MTBSully's Avatar
trust me. around here, spelling is kind of a big deal. and for the love of god its TUNE not toon.
Old Mar 19, 2010 | 12:05 PM
stburgpete's Avatar
I will pay attention to my spelling more. So how much of a pain is this switch? Long night last night sorry.
Old Mar 19, 2010 | 12:08 PM
MTBSully's Avatar
like listed above, you would need to buy all of those parts. Also like has been said, OBD-1 is much easier to tune than obd-2.
Old Mar 19, 2010 | 12:15 PM
the_merv's Avatar
The only thing worth going to OBDII is using the LS Coils and PCM..
Old Mar 19, 2010 | 08:15 PM
gregrob's Avatar
OBD-I software is cheap or FREE
