Light weight battery
Old Mar 21, 2010 | 05:15 PM
OlMastaScrilla's Avatar
Default Light weight battery
I was lookiin into getting a lightweight battery and battery hold down for my 95 z28. I came upon the braile batterys and they look like what I want but im unsure what model to get. Has anyone done this/what model is the best? I am only running an alternator also, the lighter the better. Thanks for the help
Old Mar 21, 2010 | 05:19 PM
mklinger's Avatar
Default Light Weight Battery
I'm running a Miata battery from Stabb. AGM with 470 CCA and 26 lbs.
http://www.staabbattery.com/category...Batteries.html
Old Mar 21, 2010 | 05:21 PM
thehammer69's Avatar
I use a PC680 from Odyssey in my Z06.
http://www.odysseybatteries.com/battery/pc680series.htm
Old Mar 21, 2010 | 05:26 PM
sweet thanks for the help guys im thinkin pc680/billet hold down now but still open to options!
Old Mar 21, 2010 | 06:45 PM
96blackta's Avatar
Hm... I have a used pc680 that was only used for a few hundred miles.
Old Mar 21, 2010 | 07:07 PM
z_speedfreak's Avatar
modularturbo sells some nice lookin lw batteries> https://ls1tech.com/forums/sponsor-s...e-battery.html
Old Mar 21, 2010 | 08:57 PM
96blackta's Avatar
$99 is quite a deal for an 11lb battery.
Old Mar 22, 2010 | 12:21 PM
That is a good deal I will definately think about it. 96blackta Why did you only use the pc680 for a couple hundred miles?
Old Mar 23, 2010 | 10:37 AM
96blackta's Avatar
I got in an accident with my bird :[
Old Mar 24, 2010 | 02:42 PM
damn that sucks... Does the pc680 just connect right to the stock cables or is there an adapter i need?
Old Mar 24, 2010 | 04:16 PM
BOLO's Avatar
I have been using Braille B2015(15 lbs.) lightweight battery with no issues. But then the car is a weekend only car with no accessories(stereo,a/c, p/s). You can purchase adapters from them or pep boys.
Old Mar 24, 2010 | 04:53 PM
Sweet thanks for the info. My car only runs an alt and is only weekend driven also so hopefully it wont be an issue.
Old Mar 24, 2010 | 04:58 PM
GIZMO's Avatar
The battery is the last place that I would try to save weight. In my Stocker I had to make room up front to fit a larger battery!
Old Mar 24, 2010 | 10:53 PM
96blackta's Avatar
I modified the battery cables and added connectors. Didn't 'need' to, but it was much nicer.
