valve spring/roller rocker install
Old Mar 21, 2010 | 06:18 PM
06hemi's Avatar
Default valve spring/roller rocker install
i feel sure theres a tread on here somewhere about how to do this but i cant find it ive got a 93 z28 and am tring to do this w/ heads on car any tips on how to go about it would be greatly appreciated also if anybody knows the foot/pounds to tourqe the roller rockers down to or how to suggest the best way to adjust them i dont even know where to start with the spring removal part ............i need help
Old Mar 21, 2010 | 06:28 PM
thehammer69's Avatar
I have no desire to instruct how to change the valve springs with the heads on the car. There are plenty on here that will point you in the right direction.
However, I will let you know that you don't torque down your rockers.
Old Mar 21, 2010 | 08:35 PM
BigBadWhitey's Avatar
http://www.shbox.com/ci/cam_removal.html
Hope he doesnt mind me linking this.
Scroll to the bottom, click on valve spring swap
Old Mar 21, 2010 | 08:41 PM
gregrob's Avatar
Get a Tim's tool, and figure out what you're doing BEFORE you start.
If you don't know how to adjust the rockers I wouldn't be attempting the swap yet.
Old Mar 21, 2010 | 10:17 PM
JAKEJR's Avatar
I created a step by step procedure for setting lifter preload which you'll need once you get the springs swapped. It's posted as a STICKY on the LS1LT1.COM on the Engine Tech Board.
I never got around to typing up a step by step on swapping springs though. Maybe someone else has one already prepared and will post it here or post a link to it.
I could type one up, but to do the swap correctly, it's somewhat involved. Many seem to think all you do is pop off the old ones and pop on the new ones, but it's more involved than that. To do it RIGHT, the installed height and seat pressure needs to be checked and verified.
Jake
Old Mar 22, 2010 | 08:44 AM
shbox's Avatar
...or just go directly here:
http://shbox.com/ci/valve_spring_swap.html
Old Mar 22, 2010 | 10:15 AM
ebeard's Avatar
Originally Posted by thehammer69
.However, I will let you know that you don't torque down your rockers.
Yep it's not a ford. You have to use the zero lash method. Shbox is a great resource for that.
Old Mar 22, 2010 | 12:09 PM
gregrob's Avatar
Or an lsx ...
Old Mar 22, 2010 | 01:13 PM
JAKEJR's Avatar
Originally Posted by gregrob
Or an lsx ...
Or an LT4
Jake
Old Mar 22, 2010 | 01:21 PM
SS RRR's Avatar
Village Troll
Originally Posted by JAKEJR
Or an LT4
Jake
er... what?
Old Mar 22, 2010 | 07:04 PM
shbox's Avatar
Originally Posted by SS RRR
er... what?
Factory LT4s has shouldered rocker studs and the rockers were torqued down (like LSxs).
