Dyno'd Lean as Hell
Old Mar 23, 2010 | 03:49 PM
  #41
wrd1972's Avatar
Originally Posted by sepno77
WOW been trying to think back to what started the problem and it just hit me like a smack on the face. My fuel injectors are the svo 30's and it was leaking about 1-2 months ago cause the fuel pressure pushed the injector to far into the intake. I just remembered I don't have the injector clips hooked up to them. I guess that will be the 1st thing I do tomorrow.
Check the electrical pins in the injectors. When I sent mine to FIC to be flow matched to ensure they were good. They told me one pin in one injector was folded down. I am confident I was on 7 injectors for quite some time because when I got them back and installed them, the BLMs changed big time compared to before I pulled them. BTW the injectors were dead nuts equal.
Old Mar 23, 2010 | 03:57 PM
  #42
sepno77's Avatar
K will double check the pins during the install. I'm sure they're fine though. I wish I had a garage I'd get it done tonight.
Old Mar 24, 2010 | 01:16 PM
  #43
sepno77's Avatar
PROBLEM SOLVED!!!
Turned out to be a leaking injector. I pop'd the hood and saw a small puddle of fuel sitting on the intake.
Old Mar 24, 2010 | 02:22 PM
  #44
wrd1972's Avatar
Good deal.
Old Mar 24, 2010 | 02:34 PM
  #45
boosted LT1's Avatar
Damn tunes?
Amazing how many problems end this way...I had a guy complain to me how I always blamed his car, someone touch his TB and it literally fell off the car.
Old Mar 24, 2010 | 02:39 PM
  #46
nik1703's Avatar
PROBLEM SOLVED!!!
Glad to see you found the problem!
Originally Posted by boosted LT1
Damn tunes?
haha, yeah man. the other day i was cleaning out my TB and i realized two of the four bolts holding it to the intake had completely backed out. fixed that one real quick
Old Mar 24, 2010 | 03:09 PM
  #47
sepno77's Avatar
Thx, I wonder what my car will dyno now
Old Mar 24, 2010 | 03:14 PM
  #48
Good luck at least it should be correct now--and changes will yeild predictable readings
Old Mar 24, 2010 | 04:33 PM
  #49
Ed Wright's Avatar
9-Second Club
Damn tunes?
Yep, it's ALWAYS than damn computer!!
You can alwasy tell which is the dumbest person in a group when something like this comes up. It's always the first one to chirp "It's the tune!"
Old Mar 24, 2010 | 07:14 PM
  #50
AChotrod's Avatar
YEP! Its always the tune. Your tune blew up my first LT1. I sent it to you for a NA LT4 hotcam tune with full bolt ons etc. Then decided to spray the **** out of it with the same tune, no retard, and stock plugs and fuel pump.
See its always the tune. LMAO!
Old Mar 24, 2010 | 07:23 PM
  #51
Puck's Avatar
Old Mar 24, 2010 | 07:49 PM
  #52
sepno77's Avatar
Epic LMAO!
Old Apr 23, 2010 | 01:33 PM
  #53
sepno77's Avatar
Just hooked up a fuel pressure tester to my car here are the results.
has 45psi car off primed.
has 40psi car on but when I open the throttle it comes down to like 35-37psi.
I unhook the vacuum off the FPR and it jumps up to 48psi and stays there even when I open the throttle.
Just wanted to ask before I spent the money. FPR?
