Motor Mount replacement help
Old Mar 24, 2010 | 12:14 PM
xxRONNIExx's Avatar
Default Motor Mount replacement help
If Im looking correctly, isn't there just one long bolt that you have to remove for both motor mounts? I have my replacements and I have no idea how to take the old ones out. If anyone has any pics of the location and some instructions on remove/replace I'd appreciate it, thx.
I may be looking at the wrong thing as well....
Old Mar 24, 2010 | 12:19 PM
bigj2717's Avatar
To take them out you have to take the passenger side center bolt out and then unbolt it from the K-member the drivers side is different but still have to be unbolted from the k-member
Old Mar 24, 2010 | 12:49 PM
the_merv's Avatar
There are two long bolts that go through the Mount and the Clamshell..those bolts will have to come out before you can lift the Engine..it may be easier to do one side at a time.
Old Mar 24, 2010 | 01:32 PM
jaycenk's Avatar
On the Driver side mount the K frame side or lower part of the mount will not need to come off. The mount is in the top part of the mount that is bolted to the engine. If the driver side is crushed real bad you may need to lift it a bit to get the nut off the back. Mine was blocked by the back engine bolt. You can also just take the back engine side bolt out if you need with out lifting the engine
Old Mar 24, 2010 | 02:01 PM
xxRONNIExx's Avatar
Thank you guys for your help. Im about to crawl under and see what I can do. Hopefully this isn't a 1 or 2 day job. I just want to make it as easy on me as possible.
Old Mar 24, 2010 | 05:47 PM
xxRONNIExx's Avatar
Well Im trying to remove the passenger side first. I took the long bolt out along with 2 other bolts connected to the K member. I have 1 more bolt that needs to be taking out (rear bolt). My header is in the way and I cant get a good angle on it to remove. Do I have to remove or adjust the header out of the way??
Old Mar 25, 2010 | 12:28 AM
the_merv's Avatar
You may have to move it.
