Wiper Problem
Old Mar 29, 2010 | 06:01 PM
myltwon's Avatar
Default Wiper Problem
ok having a problem with my wiper blades not wanting to turn on. pretty sure it's not the motor, any ideas as to what parts to specifically look at for testing/replacement?
Old Mar 29, 2010 | 06:05 PM
Drew24's Avatar
have you checked the fuses?
Old Mar 29, 2010 | 07:01 PM
myltwon's Avatar
yeah checked the fuses, was wondering if there were any specific relays or components in the steering column to look at
Old Mar 29, 2010 | 07:45 PM
Drew24's Avatar
hmm does it make any noise when they are in the on position?
Old Mar 29, 2010 | 10:03 PM
myltwon's Avatar
occassionally it would make some noise then go quiet when at the full speed position
Old Mar 29, 2010 | 10:16 PM
ssbowtie1's Avatar
Probably the motor. Does it turn on intermittently or after a few tries?
Old Mar 29, 2010 | 10:20 PM
myltwon's Avatar
it's turned on intermittently before but seems to be completely dead as of late. any guides on how to get to the wiper motor? thing seems packed in there
Old Mar 30, 2010 | 09:33 PM
stevo9389's Avatar
try cleaning the dog hair out of it. the car is getting revenge from you never driving it. jfwy.
Old Mar 31, 2010 | 12:41 AM
ssbowtie1's Avatar
Take the wipers off. use a puller and don't pry on the windshield or it will break.
Take the hood off.
Take the plastic tabs off and remove the two plastic cowl pieces.
Remove the bolts from the driver and passenger wiper mechanism.
From there the motor and wiper mechanism will have enough play to allow you to take the torx bolts out and remove the motor.
To answer your question, yes it is a pain in the ***.
Old Mar 31, 2010 | 12:06 PM
myltwon's Avatar
thanks for the small write up!
steveo screw you lol
