Watts link, LT1, polished aluminum, red powder-coat, updated pics (9-14-10)
Old 09-14-2010, 12:17 AM
  #81
SRZ
SRZ's Avatar
You must not have any kids to put that many hours into claying the car etc. LOL! Wonder how that watts link would work my T2R diff?
Old 09-14-2010, 02:13 AM
  #82
ninjai_ruken's Avatar
Originally Posted by 96silverram
Update (9-13-10):
Just took the car out for a little test romp and much to my amazement the car feels completely different, but in a good way. I have read a few different threads where people state they could immediately tell there was a difference in the car, but I questioned how true that could be without testing? Well, I was wrong. It is immediately noticeable just driving down the street. Maybe it's just me, but the rearend just feels more secure. I headed out to the cloverleaf close by to do some spirited driving around the interchange a few times at different speeds. It was very impressive to keep pushing the car in 3rd gear out of the bottom of each loop. The car seemed like I could just keep feeding it pedal input. The car use to have a fair amount of oversteer at the edge before doing the upgrade. After installing the Watts Link it's as if the car won't let me oversteer the rear. I actually was pushing the car fairly hard through the last loop of the cloverleaf and exited the corner on to the freeway at 6100 rpm's in 3rd; bang'd 4th gear, and got some scratch on the concrete I must say, I'm just about ready to purchase a set of KYB's or Koni's and take the suspension to the next level I'm going to recommend this product for two reasons: 1-it appears it really works, 2 - I think it looks really cool
HAHA I knew it! I knew it would be like night and day. I am sold, ganna be picking one up myself.
EDIT: By the way, your tags are expired > Welcome to the club....haha, In reality I just moved and the new city I moved to wants more for me to re tag and get new plates so Im headed back to my old town to pick up one last set of tags. Then going to go with new Plates Next year
Old 09-14-2010, 03:02 AM
  #83
firehawk238's Avatar
Update (9-13-10):
i am not sure how often you launch your car hard, or if you really take it to the drag strip much, but my biggest question about a watts link is if it will improve or hurt 60ft times? if you have any track time with your old suspension setup id like to urge you to try out the watts link and give some feedback. im sure this is a common question among fbody owners. i really want to do one, but at the same time i want to know if id be making any sacrifices other than weight. i also have a strange S60 and kinda worry about clearance on that big beastly thing. i dont have any special covers on it so may not have an issue. any feedback in this area will be most appreciated and should help complete your experiments on the watts link as well. thanks
Old 09-14-2010, 09:10 AM
  #84
Lgoldtop's Avatar
Absolutley Gorgeous silverman. How much did that run you?
Old 09-14-2010, 02:33 PM
  #85
96silverram's Avatar
SRZ: No kids that I know about, lol.
Ninjai Ruken: I don't think you would be disappointed from the results. Yes, I know the tags are expired. I'm so lazy, I don't even feel like I should have to purchase tags considering the car is never driven
Firehawk 238: I've been able to produce a best of 1.80 60ft with almost no mods back in 2000ish. I suspect with everything I have suspension wise on this car now it should be capable of at least 1.6x's (in my opinion). I don't think the Watts link will make one bit of difference at the dragstrip. I personally don't know how it could translate to anything negative or positive. I suspect that the small weight addition from doing this mod in miniscule in the grand scheme of things. If anything it would be a plus by placing a touch more weight in the rear of the car. I think my difference from the BMR items I removed was only an extra 6 or 8 lbs?
Lgoldtop: Thanks for the comps. I think I purchased this item for $650 and the polishing would cost you another $75 to $100. So, in total about $725 ish +/-.
Old 09-14-2010, 04:03 PM
  #86
RealQuick's Avatar
Like I have said before, you have one of the nicest LTx's on this site.
Old 09-14-2010, 08:09 PM
  #87
It's always appreciated Real Quick
FYI, Firehawk238: I forgot to mention the 1.80 60ft was with a set of ET streets launching at 5200 rpm's. The car never held any better than the 1.8's, but some of that had to do with the stock suspension. I never really have had the car back to the track since 2003 (IIRC). I would definitely be willing to do some 5,000 rpm clutch dumps on my Bogart's in the near future just to see what the results of all of the suspension work would produce
Old 09-14-2010, 09:43 PM
  #88
ThorsLT1's Avatar
Where did you get it?
Old 09-14-2010, 09:45 PM
  #89
Sam Strano, Just give him a call and he can hook you up with all your suspension needs.
Old 09-15-2010, 02:26 PM
  #90
License2Ill's Avatar
Sounds like a good investment!!!.....have anymore updates? have u been driving it around some more?
Old 09-15-2010, 04:07 PM
  #91
I actually took the car out just the other night to go get some gas and I had a little run in with white 75' SD455 poncho. It was kind of funny because I was wondering if there would be any difference at all on a street launch on BFG 315/30/18 drags and the Watts link. So, as I was coming up to the light and I see to the left of me a 1975 SD455 T/A (White with the single blue stripe). It was actually in pretty good condition and sounded like it had exhaust and maybe a small cam (factory?). I looked over at the guy and he seemed pretty stone faced about the whole deal and I decided that meant he wanted to jump me JABRONI style like us Ital's do it on the upper east coast. I almost decided to bring the revs up, but thought it would be better to just roll out in 1st gear and see if he bites. Well; he did, and so did I. About 4500rpm's in 1st he trounced the big block and I immediately pinned his car from a roll and bang'd 2nd gear and almost immediately started to pull out on him. We both got out of it and talked for a moment at the next stop light. He told me the car was factory 4 speed, stock except for a true-dual setup, with longtubes and reworked carb. He said my car runs really hard and wondered what I had done, "simply stated: I just said all the bolt-ons." I told him he had a cool piece of muscle and the car runs well. We both went our separate ways. I was wondering if anyone knew what the stock horsepower on a 75' SD455? I'm assuming somewhere in the 300 hp with 425ish torque (flywheel rated of course). My best guess with his mods is maybe a 350hp flywheel car with a bunch of torque (450ish torque). I actually have a soft spot for the 73 SD455 TA's.
PS: Once again the Watts Link made the car feel very stable in power delivery in a straigt line. Maybe its just me, but it seems the rear-end tracks better under heavy acceleration. The car just squats and goes straight as an arrow.
Old 05-11-2011, 11:50 PM
  #92
Well, bringing this one back from the dead. I just pulled apart my exhaust so I could adjust the center bolt of the propeller on my Watts link. I originally had set the bolt into the #3 position out of 7. I now have the propeller bolt setting in the #5 position out of 7. The scale starts at the bottom of the Watts, position #1 and moves to the top at position #7. If your car is at stock height you generally pick position #3 or #4. If the car is lowered, (in my case) you start moving up from the #3 or #4 position. This is dependent on how much the car is lowered, in some cases, if the car is slammed you would put it potentially on position #6 or #7 out of 7. I will give an update when I get a chance to take it out for some spirited driving, hopefully soon.
Old 05-11-2011, 11:56 PM
  #93
Moderator
BizZzatch350's Avatar
I am always amazed at how ridiculously clean this car is
Old 05-12-2011, 12:27 AM
  #94
Bizzatch350,
I just noticed your quote, "Got a lot of problem but a MAF aint one.", "99 problems, but a bitch ain't one." I'm assuming a play on JayZ
PS: It's not always clean,
Old 05-12-2011, 01:12 AM
  #95
03impala9c1's Avatar
is there any abnormal suspension noise with this over bumps etc? im considering this over upgrading my phb setup as the price is not a whole lot more.
Old 05-12-2011, 12:51 PM
  #96
There is absolutely no noise on this setup. Granted, I can only speak for my particular selection of parts. I will definitely say it has made a world of difference in my car, and I have not even taken the car out for an assessment of the newest setting
Old 05-12-2011, 02:23 PM
  #97
Moderator
Yep, it's because the cars a 93, so we kept it speed density when we did the EFI 24X.
Old 05-12-2011, 11:46 PM
  #98
itSSlowZ28's Avatar
sounds like i'm sold on a watt's link now. first on my list of suspension goodies
Old 05-13-2011, 12:02 AM
  #99
I definitely think you will like the Watts link. It makes the car feel completely different, in a good way.
Quick Reply: Watts link, LT1, polished aluminum, red powder-coat, updated pics (9-14-10)
