help me out pushrod and chit getting on my nerves
ok getting everything ready to go back together and i need to measure my pushrods .. do i need to make a solid lifter for this and what kinda wear pattern am i looking for ? using the cc503 with le2 heads and yes they have bee shaved .10 . i have my stock length comps but one person says the fit and i will be fine and another says no ... someone chime in i have searched for the correct way but keep running into dead ends
You messure with zero lash. If it is a hydro lifter then mesure at zero lash. Once you think you have the hight right, take a sharpy and color the top of the valve stem. Place the pushrod length checker you already set in the lifter and put your rockers on and you tighten everything down. Now rotate the engine so that the valve you are working on opens and closes and couple of times. While it is opening and closing check to make sure the spring on the valve is not coil binding. once you have turned it a couple of times take the rocker off and check the wear on the top of the valve stem and make sure it is in the middle and not on the outside, or inside of the stem. Then buy your push rods and do this all over again once you have the actual pushrods and check the wear pattern on the valve stem. Then reasymble and your done.
By the way you can try this with your current pushrods and see if they are the right length.
they were shaved ten thousanths... and i am using a hyd lifter .. this is what confses me if i need a solid lifter then how can i check it at zero lash and it be right with the hyd lifter. i've had so many problems i just want to do it right the first time
