installed ud pulley. Problem!
Old Apr 5, 2010 | 10:32 AM
user 648967286742's Avatar
ive called alot of shops in my area and everyone of them are telling me that i need to replace the crank. that its the only way to fix it. Im not gonna try to helicoil it bc i dont wanna **** things up any worse than they are. wtf do i do now. Lol
Old Apr 5, 2010 | 10:49 AM
bigj2717's Avatar
How far did you get the hub back on did you use an install tool to seat it all the way on? If it's not all the way in you might have only messed up the first couple of threads
Old Apr 5, 2010 | 11:09 AM
well right now i just wanna get the bolt out by myself. How can i get pressure behind the hub to help the bolt turn out? ive tried vice grip needle nose while pulling out and turning and nothing happened.
Old Apr 5, 2010 | 11:23 AM
RamAir95TA's Avatar
Shops everywhere are going to tell you to pull the crank - they want your money. I would try helicoiling or use a Timesert - either one will work fine for that application.
As far as getting the bolt out is concerned, I'd try this. Take off the pulley (the 3 bolts) so all you have left is the crank hub and the stubborn bolt. Using a hub puller, pull the hub off of the crank snout (as far as it will go). Since the bolt is still in the way, you might need to stack some washers and get creative to give the puller something to push against. Once you have the hub out as far as it can go, you can use the crank hub as leverage to wiggle the bolt back and forth and, depending on how far you get it out, pry against the back of the hub to remove the bolt or, even better, use the puller to pull the hub AND the bolt out.
Once it's out, just helicoil or Timesert. Done.
Old Apr 5, 2010 | 11:25 AM
illusions's Avatar
With the bolt being loose and just snugging up the get loose again even on the removal, I hate to say it but you would be better off just giving it to a shop to have them remove the bolt for you. there is a strong chance YOU will further damage the threads and/or crank.
Old Apr 5, 2010 | 11:30 AM
Will I have to remove the hub to install the Helicoils or Timesert?
-Edit- Thanks for all the help guys!
Old Apr 5, 2010 | 11:32 AM
RamAir95TA's Avatar
Yes indeed.
Think about this: you could spend a couple bucks doing the helicoil/timesert deal and if it works (which it will), it will have only cost you vehicle down-time and the cost for a drill bit and the helicoil/timesert kit. If you take anyone's advice about replacing the crankshaft, you're looking at a rebuild which will run you in excess of $1500+.
Which makes the most sense?
Old Apr 5, 2010 | 11:34 AM
draggin97s10's Avatar
take two flathead screwdrivers. and wedge the bolt out.
Old Apr 5, 2010 | 11:45 AM
illusions's Avatar
Originally Posted by RamAir95TA
Yes indeed.
And your assuming he has the skills and tools to perform this task. if he isn't comfortable to drill his crank then see if there is someone who has the experience, tools and skills to perform the task at hand. I would never tell someone to perform this task not knowing the skill level of the person I'm talking to. take into consideration the original task that lead to this and how it got screwed up to begin with.
Old Apr 5, 2010 | 11:51 AM
RamAir95TA's Avatar
I didn't think cleaning up a hole with the proper sized drill bit takes an immense amount of mechanical ability.
I guess it's up to him if he wants to spend the money on a tow truck and a shop to do it. I'm suggesting the cheapest alternative - that's all.
Old Apr 5, 2010 | 11:57 AM
illusions's Avatar
ok whatever but I'll just wait around for the "I screwed up my crank good this time, how do I fix it" thread.
Old Apr 5, 2010 | 12:10 PM
  #32
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
It never hurts to know all of your options.
