High beem switch
Keep in mind though that it's not the turn signal lever that turns on your brights. It just actuates a rod that pushes the switch. The high beam switch itself is mounted further down on the column, right next to the starter switch.
http://shbox.com/1/steering_column_exploded.jpg
You pull on the multi-function lever and it moves the pivot and pulse switch. It moves a rod that moves the dimmer.
